Replacement for 2200UF 6.3v KZG caps
  • mikay786
    • Aug 2014
    • 765
    From my last weeks carboot haul, motherboard has 6 x 2200uf KZG 6.3v caps that are bulging. Looking for cheep and cheerful replacements as isn't really worth me spending much on it.
    Would 1500uf 10v MCZ caps do the job as I have them in hand?
    or anything from this page
    http://uk.farnell.com/webapp/wcs/sto...0061,110130370
    FM, FR, ZL, YXG, ZL, ZLH, HM series from respective manufacturers?
    Edit) Also 3 x 1500uf 16v KZG (look fine but same series so assuming should change too)
    • 31028
    Re: Replacement for 2200UF 6.3v KZG caps
    you need the same ratings with esr close to 0.013
    rubycon ZLG is a good match
    • mikay786
      • Aug 2014
      • 765
      cant get hold of ZLG, ZLH good enough?
        • 31028
        not really, panasonic FM is better.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          ZLH will be fine. The on-hand 1500@10v MCZ's would also work fine.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • mikay786
            • Aug 2014
            • 765
            The FMs did the trick nicely, pricey little buggers though!
            Got system up and running with a W10 install, 2gb ram with a dual core Athlon. Should be ok as a little streaming box for bedroom telly.
