EPOX 8RDA3+ - Very low -12V rail
  • Richard-UK
    • Jul 2008
    Hello everyone - my 1st post - what a great forum
    I never knew this website existed until today & changed all the electrolytics on my EPOX 8RDA3+ a couple of years ago for 105C ZL Rubycons...
    However, lately, I have been having some problems with random restarts. The BIOS voltages are all withing 5% of spec, apart from one - the -12V rail, which is at -7.05V ! - Software (namely Speedfan & CPUID) both comfirm this very low voltage.
    The 400W PSU is OK & has been swapped out for a new one with no changes.
    I have rechecked all the electrolytics & they seem good (no signs of bulging/leakage). Has anyone had a similar problem before ?
    Many thanks, Richard
    8RDA3+ @ 2.2Ghx / 2GB / GF FX5600
  • stevo1210
    • Oct 2006
    • 4156
    Re: EPOX 8RDA3+ - Very low -12V rail
    I wouldn't rely on Speedfan or CPUID to find out what voltages are running within your PC. Get a multimter and test the voltages.... that's the only way you can be sure about the voltages. If your 12V rail was only 7V, I'd be surpried to even see it boot at all. I experienced my 12V line go down to about 10.48V and it didn't even want to boot after that.... I changed the PSU and problems went away.... I can see you have tried that with no success, but I'm curious to know what brand PSU you are using?.
    Thanks.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the meter will tell you whats up.
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • lefetylorant
        Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
        by lefetylorant
        Hello Everyone,
        Long story short, I got this unit for very cheap.
        I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
        I've performed some measurements:
        - 20V rail perfectly...
        09-14-2023, 05:05 AM
      • bimole
        Weird behavior on 3.3V rail of a CORSAIR CX600
        by bimole
        A colleague gave me an apparently ill CORSAIR CX600.
        He told me that he heard a banging noise, and smelt the magic smoke.
        After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
        I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
        It's another story on the 3.3V rail...
        I have some devices to test deeply PSUs (scope, AC source, electronic load)...
        02-13-2025, 04:49 AM
      • joshAU
        Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
        by joshAU
        Hi all.
        This notebook was showing no signs of life.
        I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
        However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
        If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
        I tried replacing the MOSFET with a new one, but again no voltage on the...
        05-29-2024, 12:33 AM
