Fakes on ECS P4M800PRO-M V1.0?
  • lbwlow
    • May 2015
    • 125
    • Malaysia
    Hi all...
    Salvaged yet another board from a local scrapper, those bad caps were hiding under the HSF, well yea... I missed it. These caps they looks fake solids to me, because it has the vents mark on them. All of them were vented and their guts were shoot onto the HSF. But amazingly the board still works and pass memtest86 like no issue. What is the manufacture of these caps ? I never seen one of these before other than the Sacon FZ series. I got a bag of random solid caps that I salvaged from other dead board, gonna put those over here.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Fakes on ECS P4M800PRO-M V1.0?
    Looks like rust to me no electrolyte, have you esr'd them ?
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      Those aren't solid capacitors. Those are wet electrolytics. Supposedly made by Suncon (Sanyo) but if you desolder them you will probably find that they have a bullseye bung so I have my doubts of their authenticity (however I think that 10mm and shorter capacitors sometimes tend to have a flat bung in place of a thicker one, at least that's what Sanyo notes about their OS-CON SEPC series in the datasheet)... and those 680uF/4V series of capacitors yield a high failure rate anyway.
      • ZnsaneRyder
        • Oct 2015
        • 88
        • Merica
        Glad you have some replacement caps.
        I question the integrity of all caps in boards, they could have blown for any reason.
        On an old overclocked gaming computer I use to have, I actually added Three 3300uf caps under the motherboard in soldered in parallel to the pins with the caps on top. My PC case had room under the motherboard however. In a situation you can not find the right caps, you can do that too, just find some large electrolytics that are small enough to fit under the board, lay them down against the board, bend the legs on the capacitors to touch the board, and solder them in.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5065
          • New Zealand
          Yeah. They just have a very similar can style, but as you see, the vent gives them away.
          I don't know if replacing them with real solid capacitors is a good idea. Those have much lower ESR and may upset VRM stability.
          Research the posts on Polymodding first.
          -David VanHorn
          • lbwlow
            • May 2015
            • 125
            • Malaysia
            I have no idea what are those rusty like goo, it wasn't complete dry, and it sticks. I don't have a ESR in hand, so I just use the capacitance function on my DMM to test those caps, although they are rated at 680uf, but I am getting a reading of closing to 1000uf, and it wasn't stable, like... fluctuate between 700-900uf. But as far as I can tell, those caps are bulged, it won't stays flat when I lay it against the floor.
            Okay, thanks for the clarification, I will check those caps once again to confirm if it is made by Suncon.
            I am guessing they were blown due to extreme heat radiated from the HSF, it came with a P4 506 processor. If smart fan was enabled in the BIOS setting, the heatsink is extremely hot, the surrounding area under the board is very hot as well, unless smart fan function is disabled.
            Well... it was lucky that this board doesn't has any caps under it.
            Now I have replace those faulty caps with yellow color Fujitsu Polymer 2.5V caps, so far so good, only weird thing was, if I was using IDE HDD with IDE-SATA adapter, the PC would runs extremely slow, and even BSOD, when running the IDE HDD with IDE cable, it runs fine with no issue whatsoever.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              That means they've gone leaky (partially shorted). My guess is that when the electrolyte broke down, dried up, and outgassed (a process expedited by the aforementioned heat for sure), it was no longer capable of proving the aluminum oxide film with enough oxygen to self-heal (reform) so defects in the dielectric essentially went uncorrected for too long.
              Yes, please disable retarded "cooling systems" like that. ECS must have been very eager to bake even the best liquid electrolytics with such "cooling". That board looks to be loaded with crap anyway (OST and Toshin Kogyo). And yes, it looks like the heatsink fan was blowing that heat right across the capacitors.
              It probably means A) something is wrong with the card itself or B) the board is loaded with bad capacitors that could result in issues with add-in cards.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5065
                • New Zealand
                I have tried those IDE-SATA drive converters too. The ones I had hated AHCI\RAID and would only work with the SATA controller in legacy IDE emulation mode. Also they did not work with optical drives at all. But I am talking ultra budget ones for like $2 on eBay. You can get much better looking and more expensive ones which I'm sure work much better.
                If the board runs fine with direct IDE connection I would blame the converters.
                -David VanHorn
                • SurrealMustard
                  What parts can be salvaged from a plasma with a damaged display panel?
                  by SurrealMustard
                  I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                  03-09-2025, 08:29 PM
                • rblack711
                  LG 47LG70 Salvaged
                  by rblack711
                  I picked up this 47" TV and it didn't have a picture or sound, but it did have backlights. No visible damage on any of the boards, and all the voltages were normal on the power supply. I figured it was probably the main board, but could not find one available for this model right now anywhere. I thought I might as well try reflowing the large BGA chip as I have seen others have success doing it. I heated it with my cheapo hot air rework station for a few minutes, monitored the temp with a thermocouple, trying to keep the temperature around 450-500 deg F.
                  I was very surprised...
                  06-20-2022, 01:36 PM
                • Justin_D33
                  Is what I have compatible with this Delta DPS-250AB power supply?
                  by Justin_D33
                  Hello all. This is my Delta DPS-250AB PSU. It does not work anymore, and I'm assuming the cause is dried-out secondary capacitors. Specifically, those dreaded CapXons. I have some recap stock I salvaged from a dead ECS 945GCT-M3:
                  1, United Chemicon KZG 560 µF 6.3V, there's one of these
                  2, Sanyo WG 2200 µF 10V, there's 3 of these that came from the VRM area
                  3, more Sanyo WGs, these came from the PCIe area. There's 3 in total, they are 6.3V ones. I forgot the exact capacitance, and I don't want to dig them out right now.
                  09-30-2025, 06:23 PM
                • 5mall5nail5
                  Motherboard component ID and can it be repaired?
                  by 5mall5nail5
                  Hey all - I have an mITX board that I moved from one case to another. I was showing my son how to work on PCs (maybe mITX wasn't the best) and so he was getting a guided install of putting the board in. It booted after we swapped cases, but it was failed to POST with a CPU light on after a few times. I removed the board and noticed that this component was bumped and the legs were (possibly) touching. I went to push it back gently and it looks like the legs came off on some but also a pad might have lifted? Anyway - going to reach out for warranty/repair, but in case they tell me its dead...
                  06-02-2025, 11:29 AM
                • Bob Wong
                  MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                  by Bob Wong
                  Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                  In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                  P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                  03-15-2025, 02:02 PM
