DFI PRO875 Bad Caps?
  • nzbleach
    • Feb 2008
    Ok the symptoms are :
    *Delayed Post, sometimes not at all. When I press the power button, everything turns on but it takes a further 5 -15 minutes for it to beep and then display something.
    *CMOS will not save any info, I have got 2 bios chips that have the same issue so its not the chip. I have also changed the CMOS battery and CMOS is not set to CLR.
    *Requires 'pre-heating' my Pentium4 Prescott to around 75 degrees C before it has any chance of posting properly. I do this by unplugging the CPU fan for about 2-3 minutes, plugging it back in, resetting PC and voila, post. After it has posted it Can reset it and it will start right back up. But if I drain the caps or leave it off for a while the systems starts from symptom 1 again.
    *Caps in question are kzg caps which apparently are good? 3 or 4 of the 2200uF 6.3 volt caps right next to the CPU socket have a white substance forming on the tops of them. The prescott's run hot so I'm wondering if constant 60-70 degree exhaust air over the caps is causing this premature failure?
    Does this sound like a capacitor problem? TIA guys.
  • stevo1210
    • Oct 2006
    • 4156
    Re: DFI PRO875 Bad Caps?
    It sure sounds like a capacitor problem. The hot prescott blowing hot air over the caps isnt a good thing and those KZG caps don't like too much heat either.... and if there's a white subtance forming of top of them, i would check if it's electrolyte. I've been though some instance where I thought dust was leaked electrolyte.
    • nzbleach
      • Feb 2008
      Well, its white and im having trouble scraping it off the cap. Its only forming on some of them so I can only assume its not dust.
      • Krankshaft
        • Jan 2007
        • 2328
        It could be white silicone or some type of component adhesive they use it at the factory to secure the caps before wave soldering.
        Post some pics and we'll let you know what it is.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          KZG series capacitors are known to have problems (often with no visible indication) and it's more common if there is a lot of heat,,, Like caps right next to the CPU socket.
          Mann-Made Global Warming.
          - Dr Seuss
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • questore
            XPS 13 9370 CMOS battery voltage always low
            by questore
            Hi Everyone,
            I have brought you a mistery item
            This laptop have come with some strange faults.
            1. CMOS battery was flat 0v
            Symptoms:
            - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
            Amp drawing was stuck at 0.005 milliamps.
            - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
            After inverstigation RTCD1 diode had a low value...
            09-30-2025, 05:47 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
