Re: Help with ASUS K8V SE Deluxe
I would say with the exception of their high end gaming boards you're correct. I have had a P6T-Deluxe v2 and it worked wonderfully
I have a customer with a Maximus VI Hero with some problems. You put a usb 3.0 card in there and it reboots and 'overclock failed' all the time if it's in a pci-e slot thats connected to the ICH. Put it in a pci-e slot thats cpu connected and it works just fine. We went on for days figuring that one out. Updating the bios and many many other things. The overclocking options on that sucker was INSANE. But the overclock fail detection system was tripped with two different usb 3.0 cards, two different manufacturers and different usb chipsets.
- signal lost,"It's dead,Jim!"
No problems for a old S370 CPU,let alone a Celeron. Should get some time and install the PI coils,some Sanyo WG and SE caps and it should work fine. I actually can do without the filtering part for a PC so old.
) even in standby. It would power up fine,but shorting the PW_SW pins would turn off the board after 10 seconds,instead of 5.
