Cant get capacitor legs out!!!
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Cant get capacitor legs out!!!
    If you go to this site it will explain all about temperature and what is need for a good solder joint which also will inform you of then, what is needed to desolder a good joint.
    • diif
      • Feb 2014
      • 6978
      • England
      I have one of those Tenmas, set at 400, as stj says it takes a while to get the heat in to the part. There is a big performance increase when the tip is cleaned in brass then coated with fresh solder. Then i apply a little more solder when the tip is in contact with the leg.
      I still haven't got round to buying a decent iron, but with practice it's ok.
        • 31024
        https://www.youtube.com/channel/UCT5...PfA3_9wF3CgY1w
        • mikay786
          • Aug 2014
          • 765
          Finally got them out, ordered a new tips. Turned temp down to 320c, added lots of new solder I bought which has flux in it and got them out.
          My own fault for pulling caps out.
          Just did another identical board but this time added solder first, warmed up and pulled on capacitor slightly to pop one leg out, then the other and cleaned up the empty holes. This board took 30mins, in comparison to the other one which took days lol
          Whilst obvious to you guys keeping the tips clean, with a nice shiny coating of solder helps a lot. At least learnt a few things, tinning, keeping tips clean oxidation free and leaving a coating of solder after use.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Yes we live and learn.
            • Logistics
              • Apr 2007
              • 721
              whenever I had a cheap iron and the tips seemed to start acting like that, not wanting to tin, correctly and not melting solder joints, I would just use some sandpaper like 320 to sand the surface and then re-tin it and it would work great until it started acting cruddy again.
              Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                • 31024
                modern tips will be destroyed like that, they are iron-coated copper.
                if you sand the iron off, the flux in the solder will eat the copper away pretty fast!
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  One can use course steel or bass wool. It will not take off as much as 320 grit sand paper. Perhaps 600 grit crocus cloth would work.
                    • 31024
                    brass wool does a good job.
                    • liquidzorch
                      862D+ solder station iron out of control when fan on
                      by liquidzorch
                      Hello.
                      I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                      First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                      06-09-2022, 08:49 PM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • Prolog
                      RTX 3080 FE Identifying capacitor
                      by Prolog
                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                      I hope these photos make it clear which component I am referring to:
                      (yes, the soldering is a bit botched from removing the blown one, I know)
                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                      12-01-2024, 08:27 PM
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                      Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook Spin 713 Specification for Upgrade or Repair
                      This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...
                      09-07-2024, 03:10 AM
