Cant get capacitor legs out!!!
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Cant get capacitor legs out!!!
    If you go to this site it will explain all about temperature and what is need for a good solder joint which also will inform you of then, what is needed to desolder a good joint.
    • diif
      • Feb 2014
      • 6978
      • England
      I have one of those Tenmas, set at 400, as stj says it takes a while to get the heat in to the part. There is a big performance increase when the tip is cleaned in brass then coated with fresh solder. Then i apply a little more solder when the tip is in contact with the leg.
      I still haven't got round to buying a decent iron, but with practice it's ok.
        • 31246
        https://www.youtube.com/channel/UCT5...PfA3_9wF3CgY1w
        • mikay786
          • Aug 2014
          • 765
          Finally got them out, ordered a new tips. Turned temp down to 320c, added lots of new solder I bought which has flux in it and got them out.
          My own fault for pulling caps out.
          Just did another identical board but this time added solder first, warmed up and pulled on capacitor slightly to pop one leg out, then the other and cleaned up the empty holes. This board took 30mins, in comparison to the other one which took days lol
          Whilst obvious to you guys keeping the tips clean, with a nice shiny coating of solder helps a lot. At least learnt a few things, tinning, keeping tips clean oxidation free and leaving a coating of solder after use.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Yes we live and learn.
            • Logistics
              • Apr 2007
              • 721
              whenever I had a cheap iron and the tips seemed to start acting like that, not wanting to tin, correctly and not melting solder joints, I would just use some sandpaper like 320 to sand the surface and then re-tin it and it would work great until it started acting cruddy again.
                • 31246
                modern tips will be destroyed like that, they are iron-coated copper.
                if you sand the iron off, the flux in the solder will eat the copper away pretty fast!
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  One can use course steel or bass wool. It will not take off as much as 320 grit sand paper. Perhaps 600 grit crocus cloth would work.
                    • 31246
                    brass wool does a good job.
                    • MORETTIGIAN
                      by MORETTIGIAN
                      Title:
                      Description:
                      Procedure performed:
                      - Removed backplate
                      - Reapplied thermal compound
                      - Reassembled card
                      09-18-2025, 12:14 PM
                    • liquidzorch
                      862D+ solder station iron out of control when fan on
                      by liquidzorch
                      Hello.
                      I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                      First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                      06-09-2022, 08:49 PM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • Prolog
                      by Prolog
                      12-01-2024, 08:27 PM
                    • Agent24
                      Dick Smith Q-1760 linear power supply filter capacitor question
                      by Agent24
                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                      It has at least one problem.
                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                      I have already ordered a replacement potentiometer, so that's not an issue.
                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                      All are CapXon...
                      10-21-2025, 05:39 PM
