Cant get capacitor legs out!!!
  • mikay786
    • Aug 2014
    • 765
    Really struggling with this board, Dell XPS NVidia 790i 775, tried removing 5 caps but its been a nightmare. Ended up just pulling them out and most of the holes are blocked with fragments of the leg remaining.
    Don't understand why its so hard, its like the solder around it in unmeltable.
    Iron is 60w and desoldering gun is 80w
    Tried adding more solder but it seems to not stick properly to old solder. When I melt it seems just like its floating on the surface of the board.
    Tried putting delsoldering gun on one side and soldering iron on other end, which worked for about 3 holes but nada on the others.
    Don't know what to do, contemplating trying to drill them out now with a fine bit.
    Have ordered some super fine tips aswell in hope I can poke through but I doubt that will work.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Cant get capacitor legs out!!!
    Try putting some flux on to the solder joints then tin iron and desolder.
    • mikay786
      • Aug 2014
      • 765
      Have been using flux, I think my tips have had it as I didn't know about tinning the tip. Will do on the new ones ordered.
        • 31014
        400w iron is um - "impressive".
        got a foto of it?
        if your desoldering gun is the Duratool then it's actually about 60-70w
        • mikay786
          • Aug 2014
          • 765
          oops lol sorry 400 degrees I think.
          Ive got http://www.circuitspecialists.eu/csi...i-station3dlf/
          60w
            • 31014
            oh those Tenma units.
            i'v not heard anything good about those.
            maplin was outing them for £30 a while back.
            • mikay786
              • Aug 2014
              • 765
              is it fair to say these tips are dead? and probably one reason why im struggling?
              • mikay786
                • Aug 2014
                • 765
                The one before that was just direct to the plug, its an improvement over that!
                Id probably just break a good one but this should be fine for the odd job and to learn on. Heck I only found out about tinning tips today...
                Quick question, do the duratool tip cone things need tinning too?
                  • 31014
                  no such thing as a dead tip.
                  your temp is probably too high - you should never need more than 350'
                  put some fresh solder on the tip and then give it a good clean with a brass wool tip cleaner.
                  what solder are you using?
                  i never need more than 310' btw.
                  • mikay786
                    • Aug 2014
                    • 765
                    just some crappy one which I got in a tube, dont know what it is but I think free with iron stand I bought a while ago
                    ive ordered some of this stuff now
                    http://www.amazon.co.uk/gp/product/B...ilpage_o00_s00
                      • 31014
                      i hate leaded solder!
                      • mikay786
                        • Aug 2014
                        • 765
                        Thought leaded was better than unleaded as is easier to work with?
                          • 31014
                          not if you have a temperature-controlled iron,
                          unleaded is only a problem for low wattage mains irons like the old Antex 15w C or 18w CS series people used to use.
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            I've had boards that I became impatient with and chose to use a 100w soldering gun to free the caps and clear the holes in some locations that have wide or a lot (or both) copper traces at the joint and dissipate the heat faster than a lower watt iron can provide. The tip of my 70w temp controlled iron might be hot as hell but as soon as it makes contact with such a joint the heat decreases rapidly and will take a very long time to heat the joint up if it can. The tip size makes a big difference because the greater the mass of the tip the more heat it can hold and transfer to the work.
                            I think you ought to be able to clear those holes with what you've got but it is going to take patience. You've got to get the entire solder joint hot enough then grab the protruding lead with tweezers or a tiny needle-nose and pull it out or poke a hot needle (like a sewing needle, pin, or safety pin of the right size) into the other side of the hole and push it out. You'll have to be very patient and use flux (don't be afraid to use a lot of flux) and fresh solder on the tip but it will eventually clear I bet. The key thing is being patient.
                            I don't think your tips are shot. They just need cleaning and tinning is all.
                              • 31014
                              Originally posted by SteveNielsen
                              IThe tip of my 70w temp controlled iron might be hot as hell but as soon as it makes contact with such a joint the heat decreases rapidly and will take a very long time to heat the joint up if it can.
                              that's a poor iron design.
                              look at what the good ones can do!
                              Weller WSP80:
                              https://www.youtube.com/watch?v=gd_8...ature=youtu.be
                              Chinese Hakko T12 clone:
                              https://www.youtube.com/watch?v=u588...ature=youtu.be
                              JBC C210:
                              https://www.youtube.com/watch?v=iyz-...ature=youtu.be
                              JBC C245:
                              https://www.youtube.com/watch?v=oTdQ...ature=youtu.be
                              i intend getting the T12,
                              those JBC irons are amazing, but the price is taking the piss.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Lead free solder requires a higher temp. which is want is probably on the board. The tenma 60 watts soldering iron is what the input power is. The iron maybe is 40 watts. If your board has multiply layers than you will need way more wattage. 100 watts is not unreasonable because all those planes with-in the board have to be heated at the same time. I have seen irons that are capable of 270 watts for a limited time. Of course the wattage may also be dependent on the tip. Small tip area the wattage can keep up. Larger tip area requires more wattage to heat that area. My opinion is the Metcal station is safest iron to use as it determines magnetically what the material that is being solder and adjust for that material so the board will not be burned by to hot of an iron for to long.
                                  • 31014
                                  the tenma has slow response and recovery, that's the problem with them.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    As a Professor on Electrical Engineering told me once wattage is what determines the power required to heat the joint. Wattage is power. One can use the formula F= M*A to confirm this.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      You may not need higher than 350, but going higher shouldn't make it any harder to solder. I have mine cranked up all the way to 500*C, and I've never had issues.
                                        • 31014
                                        i as refering to the oxidised blue tips.
                                        if your temp is too high the flux burns and the tips need cleaning.
                                        • liquidzorch
                                          862D+ solder station iron out of control when fan on
                                          by liquidzorch
                                          Hello.
                                          I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                                          First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                                          06-09-2022, 08:49 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                          Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook Spin 713 Specification for Upgrade or Repair
                                          This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...
                                          09-07-2024, 03:10 AM
