Fuhjyyu?
  • djpc47
    • Dec 2007
    • 17
    Fuhjyyu?
    can someone tell me if these are Low ESR caps or not.. is it just safe to replace em with any other better brand cap of the same value?.... attempting to replace all the caps in a CWT-450, has all Fuhjyyu caps... replaced the 6.3v caps with low esr caps but dunno about the others that are 10v's
    Fuhjyyu 3300uF 10v TNR
    Fuhjyyu 3300uF 6.3v TMR
    Fuhjyyu 3300uF 6.3v TNR
  • djpc47
    • Dec 2007
    • 17
    Re: Fuhjyyu?
    also should I replace all fuhjyyu or is it safe to leave smaller ones;P?
    • Krankshaft
      • Jan 2007
      • 2328
      Re: Fuhjyyu?
      The Fukyuus on the Secondary of the supply are Low ESR you should also replace the two 1000uf caps near the rear fan since they fail too. You can use general purpose on the 2 1000uf but I used Low ESR since it couldn't hurt.
      The TM series is low ESR and the TN series is general purpose you can look them up here:
      http://www.fuhjyyu.com.tw/pro.htm
      As a rule of thumb yes you can leave the smaller caps in place if they don't have a vent pattern stamped into them you can leave them alone.
      I personally replaced them all but it was probably overkill. The smaller caps are general purpose.
      The reason the smaller caps don't have a vent pattern stamped into them is because there is not enough electrolyte inside to form enough gas to blow the vent.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Fuhjyyu?
        Also the tiny uF caps are mostly used in biasing, dc isolation, and coupling circuits vs filtering circuits so they don't heat up as much.
        Mann-Made Global Warming.
        - Dr Seuss
        • djpc47
          • Dec 2007
          • 17
          Re: Fuhjyyu?
          ok I replaced all caps... majority I replaced with brand name esr caps(rubycon, united chemi-con, nichicon, cheapest being ltec but they're mint new and other thread says they're used in xbox 360;P)..... 4700uF 10v low esr cap I didn't have any so replaced with a 1400uF 50v rubycon + 3300uF 10v United Chemi-Con paralleled, which I was told results in low esr...
          other thing... now that I replaced all the caps should this power supply be trustable on a newer system... or what??? previous to cap replacing the psu was working, never died.... some people were saying something about ripple current on some psu's.... should I be worried?
          sidenote: I ordered off ebay service manual for Tektronix 2235 oscope so I might be able to fix one up later but for now I got no oscope.... so in your guys experiences should this be trust worthy now?:P
          • gonzo0815
            • Feb 2006
            • 1600
            Re: Fuhjyyu?
            Test it on the bench with a dummy load (a few older HDD`s, resistors light bulbs or similar) and a DVM.
            If this is showing you a stable voltage within the ATX spec, you can try it. Except for the Ltec, i think it should be fine if the PSu is a trustworthy one.
              by momaka
              03-12-2025, 03:42 PM
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • edith
              Caps and how to find one to replace
              by edith
              Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
              Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
              Thank you!
              06-11-2023, 05:00 PM
            • Mattz_GT
              Which caps to replace: ECS P4M800Pro-M V1.0A
              by Mattz_GT
              It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
              I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
              Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
              Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
              PS. Additional diagnostic,...
              01-22-2025, 12:12 PM
