*** Class Action Lawsuit Against Abit ***
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #41
    Re: *** Class Action Lawsuit Against Abit ***
    Originally posted by Junk Parts
    Well now! I was just getting ready to clean up my VL6, and send it to Topcat for a recap. Now I find that Abit might/might not fix it for me. I think I'll still entrust my recap job to Topcat. I don't want to buy a new CPU, Fan, RAM, ect... My FCPGA PIII 1GHZ @ 512 Megs of PC133 RAM work just fine for me. She runs real well on my DSL. This old PIII also runs better than my Gateway P4 1.5GHZ @512 Megs of PC 133 RAM. These two PC's are programed the exact same way, and are used for the exact samethings. I still have my old AMD-K6-2/450AFX CPU. Maybe I'll just build me a killer PC arround this fine old dog CPU....LOL I still have Dos aound here somewhere too!
    roflol on your username!
    many of my sytems are built of upgrade pulls and recap jobs.junk parts to someone else.
    as far as dos i have one box here with a microsoft os on it and it is dos 6.22 for a device programmer.windows=
    • sLowEnd
      • Aug 2008
      • 33
      #42
      Well abit's gone from the mobo business (As of the end of December last year)
      • KeriJane
        Mac Enthusiast
        • Sep 2008
        • 681
        Yup.
        Darn. ABIT was a great company that got killed by two things:
        1- A Class-Action Lawsuit that drained their finances and ruined their reputation. Surprisingly, many of their competitors had the same bad capacitors issues and were not dragged into the courts. They apparently avoided losing lawsuits by denying any problem! (Honesty gets punished)
        2- Marketing a highly technical product to the general public (computer motherboards) with long warranties and generous return privileges... a sure recipe for high return rates of used and/or damaged boards rendered unsalable. Obviously, many of the returned boards were not in the least bit defective, problems being anything from incompatible CPU/memory installation, to really bad PSUs, to physical damage and even "I returned board "A" because the new board "B" came out"..
        Oh well,
        Keri
        The More You Learn The Less You Know!
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          #44
          also didnt help that abit repaired these boards by just replacing the visibly bulging caps.
          wake up they were ALL bad when they were made stupid!
          i have seen plenty of the supposed "repaired"abit boards land here for a proper repair.
          • bgavin
            • Jan 2007
            • 1355
            #45
            I hope my Abit IP35 Pro lasts a long time.
            I am 99 44/100% delighted by this board.
            The AT12V socket at the very northwest-corner of the board is a bugger to reach with a Zipang cooler in place. That is literally my only complaint.
            I liked the Gigabyte boards, but their chronic DPC latency problems, and inability to release BIOS with proper Core2 Duo support made me look elsewhere. I sold off all my stock except for one that is running (well) in a customer machine.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              I have an Abit KT7 with tons of bulged caps on it... I don't know if I want to recap this board. The weird thing is that with some bios settings this thing is still rock solid...
              But with other bios settings I don't know if my RAM is any good...
              • madan1
                DALI SUB E-12F class D, fluctuating power rail
                by madan1
                Good day everyone.
                I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                The normal value of the positive and negative power rails is +/- 43V.
                The positive rail stays...
                10-15-2025, 10:33 AM
              • dicky96
                What 'class' is this Hill Audio DX3000 Amplifier?
                by dicky96
                Hi guys, this is general query really
                So I have a Hill DX3000 3KW audio amplifier here.
                It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
                I was wondering what class this is. It doesn't fit the description of class A.
                It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
                I looked for 'class A push pull' but that didn't tell me anything either
                05-04-2022, 04:20 AM
              • Foetuss
                Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                by Foetuss
                Hi all
                Hope this is in the correct place.
                I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                Could use some double checking to see if I'm not doing something stupid .
                Pictures of the boards are attached.
                What I will be replacing with what : (planned)
                Soltek Golden ::
                4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                01-18-2025, 11:44 AM
              • japlytic
                Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
                by japlytic
                For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
                Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
                09-06-2023, 08:50 PM
              • presario425
                RIFA Class Y Capacitor remedy
                by presario425
                Hi all!
                I have a piece of gear with a Power-one SPL130 power supply in it. On the primary side, there is a very tiny (about the size of your thumb nail) RIFA Class Y capacitor, 2.2 nF. I'm not too sure about the condition (whether or not it's cracking) but I do know that it's there.
                I'm aggregating information as to how I should remedy this. It hasn't exploded yet, but that's what I'm trying to avoid.
                I've never seen a RIFA class Y safety cap self destruct (or at least it hasn't been documented in the past). However, it's not worth the risk to leave it in there....
                05-19-2020, 06:53 PM
