msi z87x-oc no post
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    msi z87x-oc no post
    hi, i got this motherboard with bent cpu pins. after replace the cpu socket, pc power on but debug card remain on number 15 (like no ram).
    if i measure vdimm voltage, i have 1.7volt withour ram and 1.5volt if i insert ram, so ram should be working.
    how can i test if it's a cpu oscket problem (maybe i soldered it wrong ) or it's a other problem?
    i reprogrammed bios chip, but still the same.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: msi z87x-oc no post
    You probably soldered it wrong, or the CPU's memory controller fried.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • Agent24
      I see dead caps
      • Oct 2007
      • 5063
      • New Zealand
      Do you have all the other voltage rails for the system?
      -David VanHorn
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        ok changed with another socket and still no post . it looks strange since i have soldered plenty of things with my bga rework and all other work were ok.
        i got this and another board not working after a socket change. whac can i check to see what is wrong with them ?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5063
          • New Zealand
          Do you have a schematic for it?
          -David VanHorn
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            nope... no schematic
            • Agent24
              I see dead caps
              • Oct 2007
              • 5063
              • New Zealand
              Hmm.. all I can think is check all power rails - maybe start with CPU vcore? check VID signals too if that's wrong, check all the main control signals like sm_reset(I think it's called?) etc.
              Probably hard without a schematic though. What is the MSI model number (like MS-7166) or such on the board? Might be easier to find a schematic with that.
              -David VanHorn
              • DoOm86
                Doubts about: working laptop without a soldered ram/vga/battery
                by DoOm86
                I'm new to elettronic, so perhaps my question has no sense.
                Can a laptop still work without one of the soldered ram?
                I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
                I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
                Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,...
                04-14-2023, 05:05 AM
              • acedogblast
                Soldered wifi upgrade to wifi 7 BE200D2W from older AX2xx based moduels.
                by acedogblast
                I have finally found a source for Intel's BE200 wifi soldered "1216" sized modules (not the larger 2230 removable M.2 modules) and I was wondering if it is possible to swap the older AX2xxD2W wifi 6/6e with this new wifi 7 module on a laptop. Supposedly both the BE200D2W and the older AX2xxD2W chips use the standard "M.2 1216 footprint" but with an additional inner-ring of pads. We have schematics of various laptops that use the AX2xxD2W chips on this forum. What we need is a schematic of a laptop that uses the new BE200D2W to check if the pinout is identical or not. Do anyone...
                11-16-2024, 10:19 PM
              • Sparklingx
                CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
                by Sparklingx
                So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
                So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
                now all...
                08-29-2024, 01:53 PM
              • Lukosiukas
                Asus GA401Q disabling soldered ram
                by Lukosiukas
                Hello, i have question about ASUS ROG GA401Q, the integrated "soldered" ram has many errors when testing with MemTest, can i disable it ? i have access to all soldering equipment, bios programmer.
                Have a nice day!...
                06-06-2024, 02:33 AM
              • madfreak
                ASUS FX504GM not turning ON
                by madfreak
                Hello everyone...i will start a series of posts with laptops that are my nightmares .
                This time i have a laptop ASUS FX504GM after burned mosfets in the CPU power supply section.
                Laptop motherboard model : DABKLIMBAB0 REV. B
                CPU : i7-8750H
                GPU : GTX 1060
                Laptop history : Laptop has burned mosfets (including hole in the motherboard) near the CPU.
                The burned mosfets were exactly : PQ94, PQ95, PQ96
                After few hours of work ( restoring pads, connections, and removing shorts ) finally i have tested motherboard...and...
                08-14-2023, 04:27 AM
