P6T won't start when EATX12V is connected
  • Joemanvn
    • Feb 2015
    I bought a cheap motherboard Asus P6T Deluxe of Ebay with i7 920, won't post or boot when I connected EATX 12v port. I tried the PSU from the other computer and it didn't work either. I saw the PSU fan runs and the drives light up when the EATX12V isn't connect, but when it connected then i press Power button on PC Board, saw the ligjt flashing and turn PSU fan off. I took heat sink off, then saw 1 mosfet 9025L PBm signed burn, use multi meter measure all other the showed up 9.6 k/ohm, except the 1 with signed burn nothing showed up, is it shorted? How can I replace it? I got heat gun set up 300 celsius with small tip tried to lift up, but seems hard to remove, Any suggestions would be appreciated. Sorry newbie, don't know where to load image.
    • 31110
    Re: P6T won't start when EATX12V is connected
    the motherboard has a shorted part on the 12v line for the cpu.
    i'v seen this and it's usually one of the fets near the cpu cocket.
    • Joemanvn
      • Feb 2015
      Yes, the one under heatsink, don't know which tool easy to remove it, does not affect the surface, thanks
      • crash-cyberdrive
        • Jun 2013
        • 62
        • US
        That is one ugly FET, by the way it died looks like a bad PSU caused that.
        Anyways, Test them all thoroughly, and try to have same or better specs MosFet.
        Now to remove the fet start slow, preheat the area you will be working on; as you can see the board itself is a heatsink for the mosfet. Heat on both sides at about 160-180C. Do for about 3-5 minutes.
        Increase temperature to about 250C moving the air heat gun (never keep in one spot). Add a small amount of rosin flux or clean flux, it will help to liquefy the solder. Do for about 1 minute
        Lastly increase temperature to 350-360C for no more than 30 seconds with tweezers be ready to take off the part.
        Clean the pads with solder iron and solder wick adding flux helps.
        Its my personal preference to use 62/36/2 for this kind of repair for its stability because of the silver content. But is not critical unless it is for a critical application.
        Just melt a bit on the pad and place the replacing component and re-flow with the air heat gun.
        Been doing this very same procedure for some time with multiple boards with very good results.
        Hope you are able to fix your P6T Deluxe.
        A Picture of subject is always Welcome
        Things saved from the e-landfill:
        Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
        Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
        MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
        ViewSonic VA712B - still working on it
        Kindle Fire USB Connector
        MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
        MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
        The list will go on thanks to the people of this forum and many hours of reading.
        • sunilnjarakkat
          • Dec 2013
          • 13
          • u.a.e
          P6T asus common problem-mosfet PH9025L 25V-66A
          • mikan
            • Dec 2015
            • 6
            • usa
            I have an xfx x58i which is the same generation at least, with no power when you press the power button. Forcing the power supply on the boot code is just 00, and no bios reaction.
            I also have a p6x58d that is basically the same as the p6t which runs for a random amount of time, usually around 5 minutes, but had it on and running as long as an hour before it locks up. This happens even in bios..any idea on that one especially?
            Both these boards have broken pins in the sockets, but I've attempted repair of them. The p6x58d is just a ground pin.
            Would a broken pin in the xfx on a pin which is dealing with memory prevent the system from turning on the power supply, or would it be something else?
            I've been searching for any x58 lga1366 schematics in order to understand power troubleshooting better, but not had any luck with this generation of boards. Not one schematic seems to be available anywhere on the web for them.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • survivalbloke
              Acer Predator Helios 300 - will not power up if battery is CONNECTED
              by survivalbloke
              This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
              06-25-2025, 12:20 PM
            • beogeek
              820-2915-A Wont power on with battery connected
              by beogeek
              Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
              I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
              After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
              So to cut the long story short I've replaced U7000,...
              02-26-2022, 01:29 AM
            • muhuruu
              PS5 too many USB devices connected
              by muhuruu
              Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
              05-19-2025, 07:14 AM
            • versionlab
              Weird problem, laptop stays on when connected to another pc
              by versionlab
              Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
              Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
              After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
              10-26-2022, 03:43 AM
