icom v8000 bulged smd caps
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    in the face.
    first bulging small smd i have seen.
    • 31247
    Re: icom v8000 bulged smd caps
    what voltage is it, and dont say 50.
    i'm just thinking as it's only 2.2uf a tant may be better.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i will use 25v tants.
      highest voltage is +5.
      • mmartell
        • Oct 2013
        • 3189
        Have you measure it ? I mean, is the device not working right ?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          it howls.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5065
            • New Zealand
            How old is that thing? Might pay to replace the lot. I recently replaced all the SMD electrolytics in a Roland KR3500 because after many years they were ALL leaking, and for some it wasn't even obvious because the plastic base hid the evidence.
            Not one was bulged, either.
            -David VanHorn
              • 31247
              i'v never actually seen one bulged, just leaked.
              i didnt think the bung was good enough to let them build enough pressure to bend the can.
              • japlytic
                • Oct 2005
                • 2086
                Some of the early SMD electrolytics are prone to failure, especially in devices which can get hot inside.
                I am also curious if there were SMD electrolytics which were not solvent resistant.
                • yildirim05
                  • Mar 2015
                  • 11
                  • turkey
                  OK
                  +frekans and high power tx capasite termal uff
                  TA6ANO
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Interesting. Also, they seem to look like they were made by Panasonic. The text font and clear (easily visible) lettering reminds me of them.
                    Perhaps there is a faulty circuit design? Or maybe the cap was manufactured incorrectly. (I see it's plastic base and band match the other caps, but maybe it was marked the wrong way around)
                    But, damn, looks like that thing is ready to launch!!!
                    How old is the device (radio?) that this was in?
                    Muh-soggy-knee
                    • re-atari
                      Denon AVR-X2000 mainboard caps bulging
                      by re-atari
                      I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
                      I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
                      09-23-2020, 10:37 AM
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
