[pics] GA-7VRX and a blown square black thing (replaceable?)
  • TerroX
    • Nov 2004
    • 6
    Check out my picture. I can get more if needed.
    GA-7VRX rev 2.0 with bulged caps and a blown part.
    Is it possible to replace the black thing?
    I also have another question which I might have to post as a separate topic. I got another Gigabyte board (my 4th and last!) which is a GA-7N400 Pro 2 (rev2.0) which makes VERY annoying whistling noises when Graphics/on-board Network card is under heavy load - coil buzz I think, but I can not locate or stop it.
    5
    Yes
    0%
    3
    No
    0%
    2
    http://borganism.com/misc/ga-7vrx_bad_capacitors.html
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    maybe.
    post a close up of the black thing.
    does the board still post?
    i see a lot of these with blown caps and most are repairable.
    • TerroX
      • Nov 2004
      • 6
      Here we go
      I also had a power supply explode a few days after this with a similar blown part - different computer though.
      • TerroX
        • Nov 2004
        • 6
        Oh, I do not know if it POSTs or not, I don't think it does but I can't remember if I checked and I can't really check very easily.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          thats a mosfet.
          part of the vrm.
          with a bit of luck thats all it needs.the 3 unburned are the same.
          worst case is it dumped +5 or +12 into the cpu core and mem and killed everything.
          • TerroX
            • Nov 2004
            • 6
            Righto.
            The RAM and CPU were fine, I moved them to another board.
            What is the Mosfet part I need. one of these mosfets?
            Is this suitable to replace the 1000uF 6.3v capacitors? possible 1000uF unit[/url
            • TerroX
              • Nov 2004
              • 6
              Should I also replace the two bulged green caps? I know they are also 6.3v but I dont know what their uF rating is unless I take them off.
              Does it matter if you use 1000uF 10V to replace a 1000uF 6.3V ? is that better or worse than the original?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                in a pinch the 10v caps will be fine.
                all caps 1000> mfd should be replaced.
                i keep scrap boards around as organ donors so i dont buy any of those mosfets.
                try digikey.
                • TerroX
                  • Nov 2004
                  • 6
                  this mosfet http://www1.jaycar.com.au/productView.asp?ID=ZT2271
                  or this one
                  http://www1.jaycar.com.au/productView.asp?ID=ZT2276
                  • gg1978
                    • Dec 2004
                    • 431
                    Yeah, that's a blown MOSFET, but as kc8adu says, it may still work, provided when the MOSFET failed it didn't hurt anything else. Soldering those on is a pain though, as the tab is soldered directly to the board, and it requires a good bit of heat, and MOSFET's dont' tolerate a lot of heat when soldering.
                    • cmlewis89
                      LG 47LB5DF blown power supply board
                      by cmlewis89
                      Hi folks,
                      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                      09-03-2024, 07:50 PM
                    • drscoot
                      HP X360 convertible battery blown fuse error, not charging
                      by drscoot
                      HP Modelnumber: 14-dh0061nb​
                      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                      All these 3 batteries are charging...
                      12-15-2023, 05:54 AM
                    • swerg
                      Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                      by swerg
                      Hey everyone,
                      I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                      I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                      I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                      06-06-2024, 03:39 PM
                    • MrzPdlch
                      Blown fuses on Gigabyte GTX 980TI 6GB
                      by MrzPdlch
                      Hey everyone,
                      I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                      Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                      Find some pictures of the actual GPU together with a picture of how it should look like.
                      I also wonder whther it might be a problem that there...
                      03-10-2024, 04:14 PM
                    • cheeky2
                      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                      by cheeky2
                      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                      06-15-2025, 05:12 AM
