Flashing AM4 BIOS with CH341
  • Peter_1402
    • Jul 2025
    • 12
    • Singapore
    Is it impossible to flash Asus TUF B450M-Plus Gaming BIOS(25LB128D) with CH341? I have done it with H270N BIOS.
    I used NeoProgrammer and selected 25LQ128C IC since 25LB128D is not in the chiplist.dat. I get no response from IC.
    Any expert can help on setting up the import.xml so that I can import 25LB128D into chiplist.dat.
    Thanks in advance.
  • m1ch43lzm
    • Mar 2019
    • 892
    • Peru
    You also need an additional 1.8V adapter like the one pictured when using CH341A, all Ryzen boards use 1.8V BIOS chips
    Selecting GD25LQ128C_1.8V should work
    • Peter_1402
      • Jul 2025
      • 12
      • Singapore
      @m1ch43lzm, Thanks. I have a CH341A and it voltage selector switch. I selected 1.8V. When I click detect on NeoProgrammer, the LED turn green momentarily and turn red.
      • m1ch43lzm
        • Mar 2019
        • 892
        • Peru
        Are you using a clip or desoldered the chip from the board
        If using clip, try removing CPU from socket
        It's best to desolder the chip
        Also try with AsProgrammer
        https://github.com/nofeletru/UsbAsp-flash/releases
        • Peter_1402
          • Jul 2025
          • 12
          • Singapore
          @m1ch43lzm, I managed to program the BIOS chip with Rev 4622. But the USB device over current still there. I have to remove the bad ESD protection chip which is still on the motherboard.
          • m1ch43lzm
            • Mar 2019
            • 892
            • Peru
            https://www.badcaps.net/forum/troubl...rrent-detected
            https://www.badcaps.net/forum/troubl...nt-modded-bios
            Boardview
            https://www.badcaps.net/forum/troubl...ing-schematics
            Hardware problem, maybe something wrong with USB_OC signals, check the area marked with a red circle
            PM_USB_OC_x
            S_USB_OC__ALL
            USB_OC_12
            USB_OC_3456
            • Peter_1402
              • Jul 2025
              • 12
              • Singapore
              @m1ch43lzm, Thank you very much for your tips. I will look into it. But first, please help comment on my findings. I just learn how to use boardviewer. 😁 I measured +5V for UD5 and OD400 and both showing ~4.5V. Can the low voltage triggered the USB device over current detection?
              • m1ch43lzm
                • Mar 2019
                • 892
                • Peru
                Use FlexBV Free https://www.badcaps.net/forum/troubl...acos-and-linux
                UD5 is on the USB data lines, OD400 is on the PS/2 keyboard data lines; the USB overcurrent detection is somewhere else
                Maybe check at pin 3 of UD700, S_USB_OC__ALL, and back track from there
                • Peter_1402
                  • Jul 2025
                  • 12
                  • Singapore
                  @m1ch43lzm, I will look into it and get back to you. Thank you very much.
                  • Aliencomputres
                    • Aug 2019
                    • 217
                    • România
                    remove the bios battery or better yet, desolder the bios chip and reprogram it.
                    • Peter_1402
                      • Jul 2025
                      • 12
                      • Singapore
                      Aliencomputres, I downgrade to 4604 and still no good. So, it's not BIOS issue. Thanks.
                      @m1ch43lzm, I have looked at UD700 and having a hard time tracing. The is no UD64 in the motherboard. Is this normal?
                      Before coming to Badcaps, I have removed UD6, UD7, UD21 and UD24. I stop at UD24 because the PC booted up OK. But the problem came back the next day.
                      These are SOT23 6pin IC aka ESD protection diodes / TVS diodes. All these chip have Asus internal marking. Any idea which part I can buy to replace them?
                      Thanks.
                      • m1ch43lzm
                        • Mar 2019
                        • 892
                        • Peru
                        Thanks.
                        Did you try the modded 4622 BIOS from here: https://www.badcaps.net/forum/troubl...nt-modded-bios
                        It's in .cap format, so should be possible to flash via USB with EZ-Flash
                        Those diodes you removed are unrelated, those are protection for the data lines (D+, D-), the actual issue with "overcurrent" is related to the 5V power supply to the USB ports
                        Measure voltage on pin 3 of UD700, you should have around 3.3v there
                        Check this video about USB overcurrent detected (it's in spanish, I haven't found a similar one in english yet) https://www.youtube.com/watch?v=FCHFMEJflbE
                        What he does in the video, is checking if the 5V is present on all the USB ports (including front panel USB), and he's also checking the voltages at the resistor packs that are connected to the 5V pins of the USB ports, he also explains that the circuits may vary, but the overcurrent detection signal goes to the chipset (he calls it "PCH" on AMD... but he's right) in the end
                        In his first board, it was a blown resistor (the diode was missing from factory), as the signal didn't reach the chipset (exact same ball on the chipset, S_USB_OC__ALL, as his board is another ASUS B450)
                        The next board he shows quickly (around 16-17min), it was a signal that goes to the AMD CPU socket, in your board it's related to SU3 and SU4 ICs
                        It depends where the fault is, whether it's related to the B450 chipset USB ports, or the CPU USB ports
                        On the boardview, start at the 5V pins of the USB ports, click on it, then it will show where that goes, follow it until you find a resistor, diode, resistor pack, and depending on which ports are "faulty", it will either end at the chipset or the CPU socket
                        Example: Click on pin 1 of U31G2_1 (the USB port stacked on top of the Type-C port), the 5V go to UCR196, after that it goes to UCD323, then it goes on pin 3 to a voltage divider conformed by UCR197 and UCR198, then goes all the way to the chipset at S_USB3D1_OC_1
                        I'ts tedious work for sure to track each signal, so if any of those signals is missing, you get the "overcurrent" error
                        I don't know if UD64 is supposed to be missing, as I don't have a working board of the same model to check, sometimes they design the parts to be there, but the final version doesn't have those parts fitted from factory, it happens a lot in laptop boards
                        For the ESD diodes, you may ask in the General Electronics Technical Discussion section, with close-up pictures of the markings of the diodes themselves (assuming you haven't lost them), or this thread in the laptop section: IC Marking Codes and Datasheets #2
                        Someone there may help identifying the part number from the markings, as it's not listed in the boardview currently available
                        • Peter_1402
                          • Jul 2025
                          • 12
                          • Singapore
                          @m1ch43lzm, Thank you for your reply. I couldn't ask for more. I can proceed with the debug now.
                          • kenkaniff
                            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                            by kenkaniff
                            Product Name: HP Pro x360 Fortis 11-inch G9
                            System BIOS: U94 Ver.01.08.00 10/06/2023
                            Serial Number: 5CG31946F5
                            SKU Number: 85W05EC#AK8
                            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                            I needed to remove bios password...
                            10-01-2025, 04:32 AM
                          • Loli Popu
                            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                            by Loli Popu
                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                            12-13-2024, 08:29 AM
                          • Timeeez
                            X270 - Bios flashing help
                            by Timeeez
                            I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
                            Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
                            11-30-2022, 05:17 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
