The ZIP contain the modded BIOS CAP files for PRO and PLUS, latest version 4622. They have been verified to work by user Fernon
ASUS TUF B450M-PLUS-PRO overcurrent modded bios
Good afternoon, do you have an older BIOS, like version 3002? The one you posted worked correctly, but I believe that due to some incompatibility, it is limiting my old GTX 1050 ti to PCI-E 1x. I tested it with the older BIOS, version 0402, and it worked smoothly at x8 (I'm using a 3 2200g, hence the 8x limitation). Sorry for the bad English, I'm using Google Translate, lol.Comment
Yes. I have an Asus Prime B350M-A v1 03 motherboard with a USB overcurrent fault. I removed all the protectors, checked the resistors, and checked that the voltages are correct on the 10k and 4.7k resistors. If I remove the RAM, it stays on, but with the RAM, the USB error appears. The motherboard has nothing connected, only power and the screen. My question is, can the BIOS be modified, and specifically which lines to disable this USB problem?Comment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by ASBI have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
07-02-2025, 02:31 PM -
- Loading...
