Desolder CPU socket and tools???
  • supersabre
    • Feb 2006
    • 45
    Last week i found 7 dual socket 370 (4 are abit vp6,3 are supermicro)motherboards in the dumpster.
    However the lugs for the socket are all broken, so i can't mount the heatsink on them.
    I have lot of junk socket 370 mobo with good sockets.
    i have desoldered ps2 port, usb port, vga port,capacitors before, but i don't have experience in desoldering tiny pins for the socket.
    Question: What is the best tool for desoldering cpu socket?
  • shadow
    • Feb 2007
    • 732
    Re: Desolder CPU socket and tools???
    Hmmm....I am not an electronics expert or anything like some others on this forum.
    I would say that you would need a proper de-soldering station. That should be able to suck out the solder from all pins on the CPU socket without too much trouble. It should then be easy to just lift the socket out.
    I think a bigger problem will be soldering these pins back on! I would not like to solder 370 pins that are right next to each other using a normal soldering iron! I remember years ago seeing an Infra-red soldering iron in action. That was cool! Soldering small chips is easy with them. Possibly this is something that would be needed to be able to solder something like a CPU socket back on.
    I am very confident that a de-soldering station would make easy work out of removing a CPU socket. However I am not exactly sure what would be the ideal tool to solder them back on.
    I am sure that others that work is this field would be able to tell you more about this.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      if its just the center lugs get hsf that hooks to the wider ones either side.
      the vp6 in this box had both center lugs on both sockets busted.
      how the hell the p.o managed to do that is beyond me.
      many amd hsf will do the job.shop around a bit.
      iirc i got these from xoxide for $10 ea
      • Harvey
        • Apr 2007
        • 264
        Its possible - but tricky - to unhook the cover on zif sockets and replace them. Slide a knife blade down the sides and prise the sides open slightly until it unclips. Its not easy but its possible.
        If you really need to remove the socket, break the top off and carefully destroy as much of the bottom plastic as you can, then you can get a small pair of pliers or tweezers onto each pin, heat the other side and pull it out. Cleaning the holes is time consuming though.. and you really do wonder if its worth the effort.
        I've done it once --- never again
        • Rainbow
          • Aug 2005
          • 1375
          Yes, the cover can be removed. But that will not help here.
          • stretch0069
            Screwed Up Super Moderator
            • Oct 2003
            • 2658
            • oooo ess aaaaaaaaa
            Due to extreeeeeeeeeme boredom, I started removing a zif socket. The first time, I did it the destructive way as described by Harvey. I got all the pins out and cleaned all the holes. When I put in the new socket and got it all nice and soldered in, it didn't work. Pretty sure it worked prior, just had the lugs broke off. In my case, the shipper beat the hell out of the box. (Thats why whenever I ship computers now, I remove the heatsink.)
            For my second attempt, and not quite as bored, I used an old Pace kit....PPS-220 I think. Its what I used when I took miniature component repair some 10 years ago. Anyway, I used the smallest tip I could find in the shop. I started and it was working fine. Got half-way through the job and got bored of being bored. Its a tedious job, but it can be done.
            "Its all about the boom....."
            Guns kill people like spoons made Rosie O'Donnell fat.
            We now return you to your regularly scheduled drinking.
            "Fear accompanies the possibility of death.....calm shepherds its certainty"
            Originally posted by Topcat
            AWD is just training wheels for RWD.
            • Lance Thornton
              • Jan 2005
              • 84
              You might want to see if any of them boot by simply trying a cheap cpu, memory and video card before attempting the unthinkable, and as stretch said, booooooring task of desoldering and soldering a socket 370 lug. If none of them boot, at least you haven't lost too much time. Good luck and take pics if you can.
              LT
              • stretch0069
                • Oct 2003
                • 2658
                look at it this way.....about 10 seconds per pin......thats 3700 seconds......62 minutes.....
                oooo......that job would require some booze and a couple sittings.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  i cheat.if no parts on the bottom i use a heatgun to pull the old socket and the donor.
                  a fine tip on my desoldering station makes it easy to clear the holes.
                  both the vp6 and supermicro mobo's likely need a recap.
                  • gastorgrab
                    • May 2007
                    • 320
                    Just how much heat will the varnish take? (it's probably an epoxy coating)
                    I can see advantages and bad disadvantages with doing things that way. I would guess that a lower overall temperature is needed when all the joints are softened at the same time, but won't things on the MB be heated that wouldn't normally be by heating only the exposed area's of the traces?
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      remember the board was originaly soldered by heating it and all its parts in a vapor phase reflow system.
                      i have never damaged one doing this.
                      and i repair industrial stuff that is often irreplaceable or very expensive.
                      if you want to try it practice on a junker removing the socket for reuse on the boards you want to fix.
                      • gastorgrab
                        • May 2007
                        • 320
                        Are you using a micro heat gun to focus the heat better or a standard sized model?
                        Not that it wouldn't work it's just that most heat guns i've seen are almost as large as the motherboard. It would seem like your driving in a finishing nail with a sledge hammer.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          just a common harbor freight cheapie on low.
                          just have to get the feel for the distance needed to get enough heat to melt solder and not stress the board.
                          • gastorgrab
                            • May 2007
                            • 320
                            I'll have to try that (on a piece of junk first).
                            • dicky96
                              PCIe x16 socket replacement / desolder / rework
                              by dicky96
                              I sometimes see expensive motherboards sold spares/repair with damaged or burnt PCIe x16 sockets
                              So I started to wonder, it is possible to de-solder the faulty socket and fit a replacement? At least for the non-armoured type
                              To this end I thought I would try to desolder a PCIe 16x socket from a scrap board - without damaging the board. The thought was, if I can remove the old socket and clean out the through holes, then fitting a new one should not be a problem
                              From googling - According to people responding to questions asking about doing this on computer/tech...
                              04-14-2021, 04:06 PM
                            • bshi02
                              How can I desolder chock coil in PGA370 socket mainboard
                              by bshi02
                              I have a PGA370 socket mainboard and it seems its Toroidal Choke Coils have been burnt.
                              when I power on this mainboard,CPU become get hot and keyboard bulb of Num,CAPs,SCROLL lights up but Monitor displayed black screen and no signal..
                              I tried to delsolder this Toroidal Choke Coils of 3.6uH(I doubt that written symbol of 3.6microhenry is correct or not..)But It is really impossible for me to desolder Toroidal Choke Coils with 20w or 30w soldering iron..
                              How can I desolder it from mainboard and Is it possible to desolder...
                              02-25-2021, 09:54 PM
                            • Isabella91
                              Possible to convert eMMC Socket to a micro SD Card socket?
                              by Isabella91
                              I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                              Read/Write a Micro SD Card from an eMMC Socket.
                              I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                              Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                              Not to remove...
                              01-14-2024, 05:10 PM
                            • warsztat
                              Acer AN515-57-577G JDIMM1 socket not working.
                              by warsztat
                              Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                              11-18-2024, 09:13 AM
                              Common SPI bios chip programming Questions and Answers
                              by SMDFlea
                              Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                              A: If you can`t read from it how do you expect to write to it ?.
                              Q: Why is my bios chip unreadable ?.
                              A: The programmer is faulty or has a worn or broken zif socket.
                              The USB cable is frayed,connector pins worn or some other physical damage.
                              Not enough amperage or voltage to power the programmer properly.
                              Bad...
                              09-02-2021, 04:40 PM
