ASUS A320M-K dead with hot ite 8655e chip.
  • nubie
    • May 2010
    • 64
    I tried soldering a new one (hot air), same symptoms, no response from power button and
    ITE 8655e GXS chip is getting hot.
    Click image for larger version  Name:	20241007_144115.jpg Views:	0 Size:	1.89 MB ID:	3489003
    What can make that chip get hot? Thanks
  • nubie
    • May 2010
    • 64
    It was the capacitor just below and Left of the number 17 written by the ITE chip.
    I typed into google: 'super io chip getting hot'
    And the first result was here:
    https://www.badcaps.net/forum/troubl...-super-io-chip
    The suggestion was a shorted capacitor. So I pulled out my multi-meter and sure enough shorted. Carefully popped it off with my flush cutters (It cut through the solder on one side. but the capacitor cracked on the other pad.)
    The motherboard LED lights came on when I re-connected the power, and it booted straight away.
    Lesson to me, don't buy and re-solder the chip as a first resort (I'm only out the $12 for 2x vacuum SMD tools and the chip, so it's not awful.)
    Just looked it up, I spent $9.82 for the motherboard 😂. Even with new tools I think a deal!
    The heatsink was $15, which is also fine 🤷🏼, it's white to match the case.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • double_DD
      How can I be sure that my EC chip is dead?
      by double_DD
      As the title suggests, how can I be sure that my EC chip is really dead?
      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
      03-12-2025, 07:47 AM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
    • pengamat_hebat
      Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
      by pengamat_hebat
      I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
      Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
      However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
      I also tried applying 3.3V to pin 3, but it still didn't work.
      I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
      03-25-2025, 04:13 AM
    • Jeroentje
      Asus X571GT repair chip replace and tips wanted
      by Jeroentje
      Hi
      I try to repair a asus Asus X571GT (DA0XKTMB8C0) no power no lights.
      I saw a burned (small hole in it) chip (JW10F) proberly a TPS22976DPUR, I removed it, now with power connected the laptop turns on and direct off again, power led and fn will light up.
      I found on a donor lenovo board a G2898KD1U (wa9y), looks the same ..
      Result is still the same, turns on and direct off again, first attempt is with backlight on all other direct attempts are only the power and fn led.
      Could it be the chip is to diffrent to make the laptop work again ?
      04-28-2024, 10:59 AM
