Looking for 9 pin jspi1 cable.
  • dreico33
    • May 2018
    • 36
    • Bolivia
    Hellow guys, as the title says i am looking for a 9 pin cable to conect my programmer ( Tl866ii plus) with the mb without the need to take out the bios chip in order to read it or re-program it. So far i can find cables for 10 pin jspi1 header or for 12 pin, which are not compatible. Maybe i am typing it wrong, so if you give me a hand with some links or under which name i have to look for it would ne very helpul. Thank you very much for your time. Click image for larger version
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i did not understand your question, on the IC you have 8 lines. I am using this connector to connect the ic with my programator.
    ...the quieter you become the more you are able to hear...
    • dreico33
      • May 2018
      • 36
      • Bolivia
      it accually has 9 pin but is uses the 8 pins. I need a cable that is 8 pin and goes from the jspi1 directly to the programmer. Whas you showed is clip yes but for me at least is very difficult to use it. So i i need female to female 8 pin cable. So far i can only find 10 pin or 12,
      • dreico33
        • May 2018
        • 36
        • Bolivia
        i Need something like that ..> JSPI1 Burner Programmer MSI motherboard BIOS Fresh Chip Burning for MSI Motherboard Fresh MSI JSPI1 Hot Swap Cable - AliExpress 502​
        Î’ut only the cable and has to be 8 pin .
        • mon2
          • Dec 2019
          • 14369
          Search for a 2x5 IDC female to female cable with 0.1" spacing (2.54 mm pitch). Yes it will be 10 pins but observe that one pin is broken / not used on the source. This is intentional so that you know the position on how to seat the cable for a 1:1 mapping.
          That is, mount the color coded 10 pin cable (only 9 wires are used on this design) with the same color wire aligned on both sides to the broken pin. Only then will you have a 1:1 mapping.
          Personally do not have the same programming tool so not sure if it is even possible to use your hardware + this cable to program the target flash device.
          In the end, the flash device = 8 pins + ground = 9 wires to access this flash memory for R/W/E activity.
          Are you 100% sure that this 9 pin male header on the motherboard is intended to be used with your programmer?
          • dreico33
            • May 2018
            • 36
            • Bolivia
            Thank you for your responce.No am not sure 100% that is gonna work, i am just tired every time desolder the bios Chip, apply hot air, cover with kapton tape or aliminium tape the plastic parts arround the Ic etc. This process with the jspi1 header seems much more simple and less time consuming.
            • mon2
              • Dec 2019
              • 14369
              Ok. It should be possible but need to start with a clear idea on the pin mappings of the 2 x 5 pin with 1 pin missing pinout that is present on the motherboard.
              Did they share this information in the motherboard manual? If not, you will need to use your meter in diode mode and probe away. Place one meter probe on the male pin header; other meter probe onto the flash memory device. If it tone beeps, record the mapping.
              Post a full diagram and the flash IC pin # once this is done.
              Once you have this wiring diagram, need to review the same from the target programmer tool you plan to use.
              In the end, you want a 1:1 wiring from the programmer to this target flash device that is onboard + common ground. The power will be from the motherboard to power this flash device.
              Always double check your work and wiring. Do not power on till this is confirmed - twice.
              Then start with a detection of the IDs of the flash device. If you can retrieve the IDs, you should be in good shape to perform a full READ / full Write / full chip Erase.
              • dreico33
                • May 2018
                • 36
                • Bolivia
                Ok, i will order the cable and post for the results as soon as i have them, thank you very much.
                • Herbs n spices
                  • Jan 2021
                  • 36
                  It is the Dupont 2.0mm 2x5P connectors, NOT the 0.1" (2.54mm)! The 2.54mm pitch is too big! Use a ruler to measure the distance between pins to make sure. I made my own cable with an SN-2549S Crimp tool (about $10USD on aliexpress) the 2.0mm 2x5P Dupont housing and terminals, and some ribbon cable.
                  • dreico33
                    • May 2018
                    • 36
                    • Bolivia
                    You are right bro thank you very much.
                    • Patch2
                      Cable Repair
                      by Patch2
                      I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                      01-02-2025, 06:04 PM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • conghuyms
                      I need datasheet cable eDP LCD 30 pin slim pls help me!
                      by conghuyms
                      My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
                      08-22-2025, 11:16 AM
                    • fweonea
                      HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
                      by fweonea
                      While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
                      I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
                      01-16-2024, 11:35 AM
                    • marce002
                      Help me make charger USB C cable with no cc pins!!
                      by marce002
                      Hi all, please
                      I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
                      How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
                      NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
                      here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
                      thanks in advance!!
                      11-17-2023, 09:16 AM
