I broke it, my new A8R32-MVP... crap.
  • Sparky
    High voltage
    • Jan 2007
    • 234
    My system became unstable again, in games it tends to freeze up. I've noticed sometimes while playing games I'll get this black line appear for a split moment in the screen someplace. I thought Oh snap my new X1950XT has a memory hole! So I took the PC apart, thought I'd check for a bad connection someplace, and in the process I found this:
    That cluster of small caps is right underneath the front of the graphics card. Now I don't have a clue where that dent came from, but the card's PCB hangs down some right in front of there so I might have smacked it on the cap when putting the card in. Could this be the cause of my trouble?
    If it is the source of my problem, Anyone know where I can get an exact replacement cap for that? I figure my warranty is probably void now anyway since they don't cover self-inflicted physical damage, so I might as well fix it myself. If I can't get an exact replacement cap, then I suppose I should replace all 6 in that cluster so they all match. It is a 16V, 100uF cap, with KMG written on it. I can get more info from it if needed, but I'd have to pull out my mobo to do that.
    Thanks.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: I broke it, my new A8R32-MVP... crap.
    That's a UCC KMG series part, general purpose, 105C, 5mm x 11mm case, Digi-Key P/N 565-1307-ND, $0.29USD.
    PeteS in CA
    • Sparky
      High voltage
      • Jan 2007
      • 234
      It says 16V on the side, not 25V
      http://www.digikey.com/scripts/DkSea...259153&Site=US
      This one is the same specs as the one you listed except it is 16V. Also found it on ebay as well. I'll probably go with the one that has cheaper shipping (price on the cap itself is the same).
      • davmax
        • Dec 2005
        • 899
        Seeing that it is a general purpose 100uF 16V cap @ 105C you can probably get one at a good local electronics component store. Certainly can here is Aussie.
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        Samsung 18x DVD writer
        33 way card reader
        Windows XP Pro SP3
        17" Benq FP737s LCD monitor
        • Sparky
          High voltage
          • Jan 2007
          • 234
          How can you tell between a plain old general purpose cap and the ones with more specific specs, like ESR and whatever else? I know that just plain-old caps aren't a good thing to use for the main caps on a mobo, though I have done it on two mobos so far (before I knew better). The only side effect is they boot very slow but they work fine othewise after booting up.
          I already ordered the new cap though, at least it'll match in perfectly and won't look like I've done anything to it
          • PeteS in CA
            • Aug 2005
            • 3581
            I have a UCC catalog (as well as Nichicon and Rubycon) at work. I also have a D-K catalog. [url=https://www.badcaps.net/forum/showthread.php?t=827]This thread has urls for UCC, Nichicon, Rubycon and Panasonic's catalogs, though updating may be in order.
            PeteS in CA
            • Rainbow
              • Aug 2005
              • 1375
              I don't think that this cap is causing your problems.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                whilst the dent is there i doubt it affect the cap too much
                • Harvey
                  • Apr 2007
                  • 264
                  I'd say that cap is more likely for audio (de)coupling than anything else.
                  • Logistics
                    • Apr 2007
                    • 721
                    I agree, I don't think that cap is your problem. I'd look to the caps on the video card instead.
                    • Sparky
                      High voltage
                      • Jan 2007
                      • 234
                      Really... I wondered about that, but I thought well it is right near the slot....
                      Crap.
                      gfx card is brand new too. Back from RMA because the original went wacky on me. I'm sure Newegg would love me RMA'ing again
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        Is your video card getting enough power? What kind of power supply do you have?
                        • nerdmafia
                          Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
                          by nerdmafia
                          Hi first question posting here, but no need to go easy on me!
                          I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
                          05-21-2025, 09:39 AM
                        • trex66
                          Craftsman 82345 Multimeter broke!
                          by trex66
                          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                          03-04-2025, 04:26 PM
                          Linear Garage Door Opener Control board took a crap install a new control board back normal
                          I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                          02-08-2025, 06:52 AM
                        • Jamey021
                          Yep...I broke it MOAR after fixing it. a2681 MacBook Air
                          by Jamey021
                          So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
                          Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
                          Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...
                          01-22-2025, 05:22 AM
                          Ghost Battery Gate Opener battery took a crap tonight it refused to close gave me three beeps
                          If I remember correctly this indicates a battery failure the other day I had to turn off the power going down the driveway to do something and forgot to turn it back on and the battery went dead but it charged back up and I thought everything was okay but apparently not because now it refuses to close and the battery power light and the line power light goes off when you give it a request to do something I have had so many devices that the battery have gone bad I am sick of it...
                          12-02-2024, 07:31 PM
