Perc 5i raid card - SMT capacitor torn off
  • kleung
    • 72
    So... I bought this poweredge 840 server used off ebay. In shipping, the raid card was not secured and it must have banged around.
    Found the card loose with this capacitor that popped off (surface mount).
    I've never done smt repair before but since one of the pads is torn off; I was wondering if it is possible to scrape off some of the green surface and solder it back on?
    If so, where would I scrape and solder.
    I've included pictures for your kind review and opinions.
    The card is not expensive. It seems to work even without the capacitor which is pretty surprising to me. I don't even know if I need to get it back on but I thought I would use this as a test repair.
    Don't know if I would trust it even if repaired.
    If anyone in Toronto wants the card; you are welcome to take it off me for free to try your hand at the repair.
    THanks guys.
    PS - what I don't understand is that the capacitor seems to sit on a whole copper plated area and I don't see any specific traces going through it.
    Is that how smt works?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Perc 5i raid card - SMT capacitor torn off
    The negative of the capacitor is connected to resistor R960, there is also a via hole in that path. Solder it in place then make a path up to the resistor but you need to also make sure you get a connection through the via hole...
    • kleung
      • 72
      Thank you for the quick reply.
      Now that you point it out to me, I can see the torn trace to the R960 resister.
      Many thanks for the help.
      Will update if I get it repaired but that looks to be beyond my level of skill and beyond my level of equipment.
      • theokretes
        • Jul 2013
        • 49
        Yeah it doesn't surprise me the card still works without the ceramic capacitor. Ceramics have low uF in contrast to electrolytics.
        If the via has been completely torn out, it might not be possible to get the capacitor back on properly.
        Just buy a nice adaptec SAS card and be done with it. The OEMed LSI cards are always temperamental (I've had an LSI card randomly pop spindles on my 15K SAS, and it was intermittent, the card had no defects; another LSI card just has a bloody slow text BIOS. Don't get me started on LSI's "webbios").
        • clearchris
          • Dec 2013
          • 687
          Solder the one end on the board and solder a thin wire to the other end and the resistor. If you have used a soldering iron before I think you could do this. Just be quick, once you see the solder melt, pull the iron off.
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • devsigner
            identify capacitor for MacBook Pro with rare logic board 820-02037-06
            by devsigner
            Hi
            While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
            resistance tests show a rising resistance value, indicating a capacitor.
            The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
            i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
            It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
            11-28-2025, 01:39 PM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Kemer
            Graphics Card mounting frame
            by Kemer
            Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
            As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
            I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
            What worries me right now is the possibility that...
            09-14-2024, 08:57 AM
            HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
            This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
            09-06-2024, 08:30 AM
