GIGABYTE Z68X-UD3H-B3 restart befor boot
  • mo000
    • Nov 2017
    • 285
    • algeria
    hi
    i have gigabyte Z68X-UD3H-B3 rev 1.0 the motherboard don't accept any version of windows i try to install win10 win 7 and boot in win10 and windows 7 pe live but restart after loading screen
    winxp is the only system that i can boot into
    i try a different version of bios files from the wesite ,but motherboard turns on with black screen or reboot after first screen of bios post
    of course i try many good tested ram and cpu
    i think the problem in kbc or chipset .
  • pctravel
    GIGABYTE GeForce RTX 3070 Ti OC 8GB GDDR6X GPU 0128 (A2) freezes PC at boot
    by pctravel
    I've got this 3070TI that only lit up at boot (no fans and not seen by PC). When taking it apart I noticed the PCIe GPU power plugs to the GPU had pin 3 from the top of the card pushed out of the connector. Once I got the pins realligned I put the card back together to try it again. Now it lights up and the fans come on but the PC does the normal single beep for boot and right away does three fast beeps and fails to boot. I unplug the card and the PC boots normally again. Clearly another issue with the card. Anyone see this before? Feel like some progress...
    04-05-2024, 03:03 PM
  • Fernon@Repair
    Gigabyte h310m s2h rev 1.1 Keep Restart solution pls
    by Fernon@Repair
    Gigabyte h310m s2h rev 1.1 motherboard come bios screen and keep restarting .sometime 2 3 times fan spring and off after come bios screen . some time working 15 to 30 minutes .
    I allready checked
    VCCPLL voltage ok
    VCCIO Voltage ok
    VCCIO Enable ok
    VCCSA Voltage Ok
    VCCSA Enable Ok
    VRM IC voltages ok
    Replaced VRM IC
    Replaced LM358 ic
    Re programed Bios
    But sometime motherboard working 20 30 minutes and restarting ......sometime have fan spring and off error ..........anyone have solution...
    07-08-2025, 10:16 AM
  • x16
    MSI GE72-6QR Apache Pro no boot on restart
    by x16
    My Gaming Notebook works great, but after Bios Update there is the problem that i can't do restart. Becaus on restart it hangs on MSI Logo, so no boot.
    Shut down works good, i don't know which version the old bios was. Any ideas?
    Here the upated Bios dump....
    09-21-2023, 01:09 PM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • hinisa
    Xiaomi router freezes at boot after re-capping
    by hinisa
    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
    07-08-2023, 05:58 AM
