imac 820-3478A have 12v and all led off
  • okianeko
    • Aug 2024
    • 14
    • 台灣
    Hello,I have a problem for my imac 820-3478A
    power supply have 12v to board ,but board 4 led all off.
    U8470
    PIN 1 :12.4V
    PIN 2 :0.03V
    PIN 3 :0
    PIN 4 :GND
    PIN 5 :12.4V
    PIN 6 :0
    PIN 7 :0
    PIN 8 :0
    U8450
    PIN 1 :12.4V
    PIN 2 :0
    PIN 3 :1.5V
    PIN 4 :GND
    PIN 5 :12.4V
    PIN 6 :0
    PIN 7 :0
    PIN 8 :0
    Both have a same problem,should i change Q4870/50?
    thanks
  • mon2
    • Dec 2019
    • 14660
    No, not yet.
    If you have NO leds enabled on this model, then you are missing PP3V3_S5 to drive the first LED which should be enabled once you plug in the power supply. 'It is plugged in' LED.
    Remove all power. Measure the resistance to ground of PP3V3_S5_REG @ L7610. What is the resistance? If the resistance is low, then you have a shorted part on this rail and this is causing this power rail to turn OFF.
    If the resistance is not low, then check if this rail is being enabled or not.
    Carefully, measure the voltage to ground of PM_EN_REG_P3V3_S5 at the resistor junction shown below - this voltage is used to enable the PP3V3_S5 missing power rail.
    Click image for larger version  Name:	PM_EN_REG_P3V3_S5.png Views:	0 Size:	31.7 KB ID:	3324670
    • okianeko
      • Aug 2024
      • 14
      • 台灣
      thanks
      resistance to ground of PP3V3_S5_REG is 2.5k ohm.
      I plugin power supply i didn't get any voltage by PM_EN_REG_P3V3_S5
      • okianeko
        • Aug 2024
        • 14
        • 台灣
        Q7610 PIN 2 don't get a 12v
        • mon2
          • Dec 2019
          • 14660
          Check voltage to ground on other side of the same resistor at R8590.
          • okianeko
            • Aug 2024
            • 14
            • 台灣
            both are 0V
            • mon2
              • Dec 2019
              • 14660
              PP12V_S5_PWRCTL = PP12V_S5_FET = 0 volts.
              PP12V_S5_FET
              is created only if mosfet Q8470 (N-channel) is enabled. The gate voltage of Q8470 pin #7 is 0 volts so this mosfet remains OFF.
              Gate is 0 volts because the ENABLE pin # 2 SMC_PM_G2_EN (U8470) is at 0 volts.
              SMC_PM_G2_EN is driven by the SMC @ U5000.
              Confirm if U5000 is being powered by checking the voltage to ground @ PP3V3_G3H_SMC L5001 (either side should be ok).
              This power rail is driven by PP3V42_G3H - confirm this rail is present by checking the voltage to ground of L6961.
              Respectively if not enabled, then check the voltage to ground of R6965 - check both sides of this 0 ohm resistor.
              • okianeko
                • Aug 2024
                • 14
                • 台灣
                L5001 : 3.3v
                L6961 : 3.3v
                R6965 : both sides are 12.07v
                • mon2
                  • Dec 2019
                  • 14660
                  L6961 should be 3v42. Can you confirm again?
                  Found a great study of this case:
                  https://www.xinxunwei.com/chenggonganli/06059635.html
                  • okianeko
                    • Aug 2024
                    • 14
                    • 台灣
                    L6961 3.39~3.4V.
                    thanks for this web ,but they are different board i'm not sure is work.
                    • mon2
                      • Dec 2019
                      • 14660
                      L3961 should be stable @ ~3v42. Remove all power. Meter in resistance mode. Measure the resistance to ground of L6961. What is the resistance in ohms?
                      • okianeko
                        • Aug 2024
                        • 14
                        • 台灣
                        resistance to ground of L6961 : 0.18ohm
                        • mon2
                          • Dec 2019
                          • 14660
                          Can you share the pic of the front face of your meter? What is the scale being used here? Perhaps 2k ohms is the max which means measurement is 180 ohms.
                          • okianeko
                            • Aug 2024
                            • 14
                            • 台灣
                            I found R5187 maybe died ,it should be 100k ohm front the u8470 pin2.
                            I need to check which died.
                            thanks
                            • okianeko
                              • Aug 2024
                              • 14
                              • 台灣
                              sorry about that
                              resistance to ground of L6961 : 180ohm
                              R5187 only have 100ohm is wired
                              • mon2
                                • Dec 2019
                                • 14660
                                If you are comfortable, flux and carefully remove R5187 off the board. Do not lose it although if you are in Taiwan - your local 7-Eleven stores probably stock it Use low air pressure and then carefully measure the resistance of this removed resistor. The part can go flying off the table so proceed with patience. Have done this too many times. The parts are dirt cheap and should be easy to source if in Tapei. I recall one of the largest resistor factories during the ride from the airport into the city in Taipei.
                                If at 100 ohms - that is too low and can impact the CS signal line.
                                • okianeko
                                  • Aug 2024
                                  • 14
                                  • 台灣
                                  thanks
                                  i order some smd 0402 on onlineshop,just waiting
                                  • okianeko
                                    • Aug 2024
                                    • 14
                                    • 台灣
                                    bad news ,when i change new resistance it still 0 ohm , maybe i need to check u8470
                                    • mon2
                                      • Dec 2019
                                      • 14660
                                      Carefully measure the resistance of the replacement resistors while it is on your worktable. Is the resistance ~ 100k ohms when you measure across the tips of this resistor with your meter?
                                      Next, flux and remove the resistor that is onboard @ R5187. After this part is removed, measure the resistance to ground of the PCB pads @ R5187, pin #1. This is to confirm if some other part is showing this low resistance to ground.
                                      Use flux, with low air pressure and enough heat to solder or remove the part.
                                      • okianeko
                                        • Aug 2024
                                        • 14
                                        • 台灣
                                        在工作臺上是 100k 歐姆,但在板上是 0 歐姆。
                                        • cind12
                                          GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                          by cind12
                                          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                          Resistance on 12V 4K ohms (Power present when on)
                                          Resistance on 12V PEX 4K ohms...
                                          12-08-2023, 09:09 AM
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
                                        • Stephen
                                          iMac 27” 2020 Boot issue
                                          by Stephen
                                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                          08-16-2024, 09:32 AM
