Hello to everyone.
My W26361-W84-X-02 motherboard starts but don't show image (no logo screen neither bios). Because, I have two of them I desoldered the bios chip from the no working motherboard and I soldered it to the working motherboard and the motherboard works OK, so the bios firmware isn't the problem. Below I took some measurements from the no working motherboard when is power on. Also, I replaced the RAM and didn't work again (maybe some pins from the RAM slot don't have the right voltage?). I replaced and the bios battery, and I made reset on the bios and again the problem didn't solved.
Finally I replaced the two leak capacitors where are in the red circle on the below image.
Do you know what could be the source of the problem or do you know where can I find a schematic?
Motherboard when is power on:
RAM decoupling capacitors - 1,84V
CPU inductors - 1,48V
Bios flash memory - 3,23V
 Motherboard W26361-W84-X-02 - Black Screen
