I just went through the drill on a Gigabyte GA-7VA . Swapped out drives, memory, and a power supply before checking the caps. Believe it or not this thing was still running but would become unresponsive a couple of times a day.
Gigabyte GA-7VA
Re: Gigabyte GA-7VA
I've got another gigabyte mobo in production and I'll have to keep an eye on it. It's probably 5-6 years newer than that GA-7VA (don't recall the model offhand) but I don't know that I can trust any of em.
I got a new Tyan this year and spent some extra coin so I hope I don't end up here again! Yipee."Pain and suffering are always inevitable for a large intelligence and a deep heart. The really great men must, I think, have great sadness on earth" -- Crime and Punishment, Fyodor Dostoevsky (1821-1881)Comment
Re: Gigabyte GA-7VA
Hi Dr Cherry, welcome
Thats part of the problem, they do run for a while with badcaps but you never know when they are going to lock up reboot or do other strange things.
So if you don't know about the badcaps situation you tend to blame everything but the Hardware.
This forum has probably saved a few people from sore ears
and going bald prematurely.
check the MB version by a search here but Gigabyte have used crappy caps so beware
there a good chance its got them.
Cheers
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
Re: Gigabyte GA-7VA
Be thankful those 2x 1200uF caps didn't incinerate themselves. When one shows up with those burnt beyond recognition, plan on replacing FET's too.
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Re: Gigabyte GA-7VA
Hi all
TC a question if you don't mine, is it these two caps you are referring too?
(That are the 1200 uF)
I notice they are a different brand
cant recall what it is thought (green gold writing cover) I think they still fall in to the somewhat crap category if memory serves.
the others are marked choyo
Cheers
Re: Gigabyte GA-7VA
Starfury, KC8 is correct. Replace them ASAP!<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: Gigabyte GA-7VA
Thank you KC8 & TC
I was just after confirmation it was those 2 caps marked we were talking about.
(to be sure)
I have recapped the Gigabyte MB
Had blown GSC crap on it and replaced with (as willawake did) Panasonic FM, dont look pritty but works well
(GA-7ZXE)
Cheers
Re: Gigabyte GA-7VA
My Gigabyte GA-7ZM still has Choyo & the other I can't remember, but it's running AOK in a well ventiled case powering a 1.1Ghz T'bird off a HEC 200w PSU
I do keep an eye on them, but after more than 12 months there's still no sign of damage nor symptoms, not bad considering it was a second hand board before I got it
Viva LA Retro!Comment
Re: Gigabyte GA-7VA
I have a GA-7VAXP that had those GSC crap caps on it and they were very crusty on top. I ended up replacing every cap on the board with some nichicon's about six months ago and it has rock solid every since, now my ps2 ports stopped working but the caps look OK.Comment
Re: Gigabyte GA-7VA
i have seen tiny inductors open near ps/2 and mouse.
mostly on pcchips but sometimes on others.
probably due to someone plugging something wrong/bad into it.
look for fuses,polyswitches,fusable resistors, near the ports too.
do the lights blink on the kb on powerup?
does an optical mouse light?Comment
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
by momakaMore eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
And a shot of the label:... -
Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
Gigabyte A5 X1
From motherboard:
S/N: 1TNH55ER1350895
P/N: 6-77-NH55ERQY-D02-2CGB
On sticker from the back of the laptop:
S/N: SN21351J000657...-
Channel: BIOS Requests ONLY!
This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...09-07-2024, 07:19 AM
- Loading...
