asrock fm1 a55m-vs no 1.2v (cpu voltage)
  • totto210
    • Apr 2021
    • 51
    • chaco
    Good guys! I need some help
    I recently bought a used processor, I don't know if it works, but the measurements are at least ok. what do you think?
    normal diode measurements,
    processor measurements: vcore 8ohms igp 5ohms.
    L1785 :
    with cpu 55 ohms
    without cpu 1.6k
    voltage with cpu 0.30V
    Replaced apw7120 - same result.
    Pin7 ocset to ground at power up with cpu.
    Mosfets without problems.
    Obviously vcore is missing, not to mention vram.
    Basically no 1.2v
    well, summarizing quite q36 (it was sending to ground with low signal vcore_en#) I have the 1.2v & vram but no vcore, as it should follow.
    schematic and boardview attached ty so much
    well the problem is that I basically don't have pwgood, which grounds the 5vsb of the q31.
    pwm rt8871a
    https://datasheetspdf.com/mobile/114...htek/RT8871A/1
    1- pwok 3v
    24 - vcc5 5v
    31- vcc12 12v
    47-pwgood 0v
    48-enable 1.12v
    I don't know what I'm missing to check for pwgood.
    regards.!
    [MOD EDIT]
    Added link to schematic
    • 21841
    Posted the schematic & boardview in a new thread
    Reminder: rules and organization of this section
    ​https://www.badcaps.net/forum/troubl...f-this-section
