MSI K8N NEO2 3.3V short
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    A friend got this dead nforce3 based motherboard from the junk and he asked me to try and fix it. It looks clean and undamaged but it has a 3.3V rail short all over and I don't know where it is exactly. Some fets where blown next to tha SATA controller. So far I got those off but the short is still present. The board has chemicon kzg before the vrm, matsushita and gluxon caps everywhere else. Should we just ditch this board? If it's some important ic's defect then we definitely will.
  • c_hegge
    • Sep 2009
    • 5219
    Re: MSI K8N NEO2 3.3V short
    Another suspect would be the RAM VRM. I'm pretty sure it uses the 3.3V rail.
    • tmiha71
      • Apr 2010
      • 130
      As dead IC's (supplied directly from +3.3V ), sound chip, or LAN chip are good candidates for removing :-))...
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Check Northbridge and Southbridge VRM. NB likely uses a buck regulator (i.e. 2 MOSFETs and a coil). SB probably a linear (1084/85/86 or similar). If not, check what the RAM VRM uses for power, as c_hegge suggested. There's also the AGP VRM - that usually uses 3.3V as well (for AGP 3.0, the 3.3V is brought down to either 1.5 or 0.8V). Those are the 4 major things that use 3.3V rail. Audio and LAN I usually find are powered by 5V through a 7805 or 3.3V through a 1084/85/86 linear regulator.
        I guess start removing until the short is gone. IMO motherboard should be salvageable. Now whether or not it's worth your time - that is up to you. If you want to take it as a challenge or learning experience, this would be a good opportunity.
        • shortchange
          • Jan 2012
          • 27
          To find a short or multiple shorts.
          Say the 3.3v supply has 4 ohms.
          attach your ohm meter to the 3.3 volt line.
          And using chilling spray or a heat gun.
          The component that causes a change in the ohm is or are most likely at fault.
          • pdavid
            • Jan 2011
            • 279
            • Hungary
            Thanks everyone! So far it looks that the ram vrm took some damage too. I removed another shorted fet from there and the resistance is higher but still a constant 3 ohm. I'm definitely going to try the freeze spay method!
            I'm not in a hurry with this thing so I poke around some more. If some chip is fried then it's recycling time for the board.
            • DynaxSC
              Extreme High Current & Low Voltage Short Killer ??
              by DynaxSC
              Hi Folks
              I'm looking for a extreme high current short killer solution for a reasonable cost.
              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
              After taking off the socket, the shorts dissappear again.
              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
              10-15-2024, 10:13 AM
            • Stephen
              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
              by Stephen
              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
              02-06-2025, 12:03 PM
            • adelfr2009
              HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
              by adelfr2009
              I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
              After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
              09-28-2025, 10:21 PM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • aaronkatrini
              Help me find the short circuit on this WORKING Nvidia GTX1650
              by aaronkatrini
              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
              04-18-2024, 03:15 PM
