SuperDot Motherboard Recap Repopped Caps
  • dhamrin
    • Jul 2011
    • 4
    Just finished recapping a SuperDot Motherboard. After successful power up, it re-blew the exact 2 same caps which were visibly popped in the first place. See attached picture with finger pointing to the 2 bad caps (Sanyo 6.3V, 1000mf). There were about 15 of these on the board, all but 2 of which I replaced even though they looked fine. Any ideas what I should try next? This is the first time I have had this type of problem. Thanks to anyone who has seen this before and can help.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: SuperDot Motherboard Recap Repopped Caps
    Those don't really look like Sanyo caps. Did you buy them new or resuse old ones?
    • mariushm
      • May 2011
      • 3799
      It's Supermicro, not superdot.
      Those don't look like Sanyo capacitors.
      Check the voltage on those capacitors that are swollen.
      check your 3.3v and 5v from the power supply
      check those dpak (to-263) ICs they may be shorted or overheating causing problems.
      • mockingbird
        • Dec 2008
        • 5488
        Those look like OST to me...
        Check your power supply as well... RAM is either taking voltage from the 12V/5V rail and regulating it down to 3.3v or straight from the 3.3V rail. Check the secondary caps in your PSU.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Some SuperMicro boards may just be re-badged stuff!
          One that I saw looked no better than some $45 POS. Would make Topcat cry!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • mockingbird
            • Dec 2008
            • 5488
            Motherboards are motherboards nowaday... Aside from the quality of the caps and FETs, they all revolve around fairly mature BIOS implementations and standardized chipsets with unified driver architectures. Not like back in the 80s when you had to take ROM chips back to the distributor to get flashed to fix some major errata.
            • dhamrin
              • Jul 2011
              • 4
              Bad wording on my part. Originals were Sanyos 6.3v 1000mf 8x14mm, replaced them with new Nichicon 8x15mm and a few 8x13mm of another brand (board not with me at moment). Which was another question I had: How much does height of a cap matter? I usually try to match exact dimensions, but I was in a jam and substituted a few 13mm tall caps for the 14mm originals as noted above.
              Thanks guys for the ideas on what to check next.
              • lti
                • May 2011
                • 2558
                There are a lot of caps that appear to be installed backward. It looks like the shaded section under the cap should be negative, but the positive lead of most of the black caps is on the shaded side.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  It almost never matters. As long as you match the specs of the new caps to the old ones (i.e. capacitance, voltage, ESR, and ripple current), then all should be fine.
                  Post some more pictures of the area where the 2 bulged caps are. It looks to me as if the MOSFET next to them is damaged, but I can't tell for sure.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Agreed. Those are definitely reverse-polarised. Re-recap it and put the caps in the right way.
                    Out of curiosity, why did you replace the original Sanyos? They are a very reliable cap manufacturer, and shouldn't have failed.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      umm, the popped cap is in backward.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        I agree too.
                        Muh-soggy-knee
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Good catch.
                          I think I have done one too many ASUS and old AsRock motherboard recaps .
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Same here. I've done it to all but 1 or 2 of my ASUS boards.
