Garbage ASCII in bios/DOS, always means bad agpcard?
  • Calchaqui
    • Oct 2005
    • 112
    It's an old cusl2-c black pearl, vio at 3.7v, oced CPU, ti4200, ran fine for a couple of months, now having all kind of ascii in bios and DOS, windows runs fine. memtest ok, prime95 ok. Same thing happens with a 6200agp, could be BOTH CARDS dont like 3.75v VIO (nvidia cards used to love high VIO) or maybe cpu is responsible for ascii evrywhere>
    I LOVE WWW.BADCAPS.NET
  • mariushm
    • May 2011
    • 3799
    Re: Garbage ASCII in bios/DOS, always means bad agpcard?
    It's usually bad ram on the video card or corrupt video card bios or damaged gpu chip. Nothing to do with cpu.
    • Calchaqui
      • Oct 2005
      • 112
      I really doubt about the card itself (i tested with a ti4200 n' 6200) both same ascii artifacts, i really think it has to do with the high Vio (almost 3.8v), what do you think?
      • mariushm
        • May 2011
        • 3799
        most video cards have voltage regulators on them. But by all means, why are you even asking if you get 3.8v instead of 3.3v or whatever it should be?
        Fix the power supply then... what do you want me to say.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Likely bad solder joints on the video card, sounds like that second hand Radeon 9800 Pro I got back in April, 2007.
          -> Yep, sounds like the video card.
          And, IIRC, I have another Radeon 9800 Pro that I haven't tested yet.....
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Calchaqui
            • Oct 2005
            • 112
            the overvoltage is needed to keep 133@2-2-2-5,7 timmings , sorry i didnt tell you. im gonna try another card, long life Romania!
            • luke10050
              • Mar 2013
              • 209
              yeah it sounds like a gpu problem, my 8600M GS did that to me before it failed. a good reflow seemed to fix it
              • Calchaqui
                • Oct 2005
                • 112
                All of you were right, bad video card i think, maybe overheating cause it takes a couple of hours to show artifacts (or minutes gaming)
                • luke10050
                  • Mar 2013
                  • 209
                  is the fan siezing or something?
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Does it sometimes go away after reseating the video card to come back later on?
                    My Radeon 9800 Pro did that until I chucked it.
                    And I would sometimes see it look better when moving it around when in the AGP slot when on.
                    Arc A770 16 GB
                    • Heihachi_73
                      • Jun 2012
                      • 713
                      Bad GPU, bad VRAM or bad solder joints?
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        That's what it looks like.
                        Arc A770 16 GB
                        • Calchaqui
                          • Oct 2005
                          • 112
                          I think it was overvolted agp bus someway overvolted the gpu or memory and cause that.
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • Bloodhoundje
                            by Bloodhoundje
                            03-16-2024, 03:12 PM
