Epox 8RDA3+ no POST, going for recap
  • TheReaper
    • Dec 2006
    I have an Epox 8RDA3+, which doesn't post. Fans power up and the LED indicator displays "FF" and that's all. Every other piece of hardware I use with it is tested and working. Have tried many hardware combination and CMOS erasing methods with no positive results. Now I'm thinking about recapping it.
    I have studied thoroughly this forum the last 2 days and I am now pretty sure that the caps should be the problem. There are 3 1500uF @ 16 Volts KZGs and every other cap on the board is TEAPO. Also there are no visible signs on them, no bulging, leaking or swelling, but have read here that it's typical for TEAPOs to fail without any visible signs.
    So I'm making a list of what caps I'll need and go shopping through local stores this weekend.
    If you have any ideas and/or suggestions I'll greatly appreciate them. Thanks.
    Dimiter
    Sofia, Bulgaria
  • Rainbow
    • Aug 2005
    • 1375
    Re: Epox 8RDA3+ no POST, going for recap
    I doubt that recap will fix it. Maybe the BIOS is corrupted. Also check for PCB damage around CPU socket.
    • TheReaper
      • Dec 2006
      It had some trouble to POST before, but after some attempts and unplugging and plugging back the power cord of the PSU fixed it until now. That's why I don't think it's the BIOS. Maybe I'll try to reflash it on another board, if I find one with similar EEPROM, until I find the needed capacitors. Also couldn't find any sign of physical damage on the board, around the socket and the connectors inside it. Wish me luck. And thanks for the reply.
      • TheReaper
        • Dec 2006
        Did some research and found that the bios chip on the Epox is compatible with the chips my other board (Asus A7V880) has and may try to "Hot-Swap" flash it if the recap doesn't work. But I'm still pretty sure the problem is not the BIOS.
        Anyone with a 8RDA3+ had a similar experience?
        • gonzo0815
          • Feb 2006
          • 1600
          If you got it to boot up once, than i would say recapping can fix it.
          • Big Pope
            Approved Vendor
            • Dec 2005
            • 426
            I am agree with your point. I think it is the caps problem. I have repaired the same mothbaord 8RDA3+ (PCB Made in China) last 2 weeks in my side.
            In my case, the baord is problem is SMART I/O fail, got a lot heat there, on board debug "FF".
            My suggestion, check the northern, southern birdge chipsets and SMART I/O, heat is normal or not.
            My SAMXON Capacitors Database HERE!!
            X-CON is a new brand for SAMXON's Polymer Capacitors.
            • bgavin
              • Jan 2007
              • 1355
              I bought (4) EpoX 8K7A used from an eBay seller. All four do the same thing. They hang at FF.
              All have TEAPO caps, many showing very obvious signs of failure. Leaking and swelling.
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
                no-name Radeon 9600 XT recap and cooler
                by momaka
                I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                This one was actually suggested to me by ChaosLegionnaire....
                11-06-2020, 07:54 PM
              • varunviolin007
                Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                by varunviolin007
                Hi guys,
                I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                Looking for someone experienced with older PC boards who uses...
                07-29-2025, 11:53 PM
              • kotel studios
                Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                by kotel studios
                Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                What I've tried so far:
                replace the original N-MOSFETs with beefier 60V ones for testing
                Resolder the resistors near the Vcore Jumper block
                Short Vcore...
                05-25-2025, 01:46 AM
              • Foetuss
                Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                by Foetuss
                Hi all
                Hope this is in the correct place.
                I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                Could use some double checking to see if I'm not doing something stupid .
                Pictures of the boards are attached.
                What I will be replacing with what : (planned)
                Soltek Golden ::
                4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                01-18-2025, 11:44 AM
