Weird Voltages after recapping, wont post.
  • Calchaqui
    • Oct 2005
    • 112
    PCCHIPS P17G, was working good just freeze up sometimes. Reccaped almost the whole board, w/good caps, problem is wont post, coils shows 0.3v and run extra-hot, but output solid caps shows 1.25v (right for pentium D), and input caps 10.85v. I dont know if it is one or all mosfet shorted, or could coils be bad? why i still get Vcore on output little caps?? i dont get it
    thnx for help
    I LOVE WWW.BADCAPS.NET
  • Calchaqui
    • Oct 2005
    • 112
    Re: Weird Voltages after recapping, wont post.
    Anybody out there? :S:S
    • cheapie
      null
      • Jul 2010
      • 849
      Knowing PCChips, you may have damaged the board when installing the caps. Also, it could be a non-cap-related issue (i.e. bad chipset). Did you use Low ESR caps? All the voltages sound right, but with non-Low ESR caps the ripple will be WAY out of spec, and the CPU won't like that (and you may fry it).
      • Calchaqui
        • Oct 2005
        • 112
        WHy is that buddy (about damaging the pcchips)?, I had BIG TIME trouble removing output caps, it was the hardest soldering ive ever seen.
        I've cut all the source leg mosfet leg, and they measure infinity resistance between S-D, so, 95% prob. they're good.
        Coils get ultra hot, but i've used good low esr caps. Chipset/south is not even warm? should it be?
        • euromatlox
          • Mar 2013
          • 60
          • Finland
          There are only a few caps around cpu, so it might be that those must be supergood and superlow esr caps. You must compare the datasheets of the originals vs replacements, to verify that ripple current capabilities are close enough or better on replacements. Power source unit can also be (quickly) checked for leaking caps.
          • Calchaqui
            • Oct 2005
            • 112
            I'm almost giving up with this one....Maybe those ultra hot coils are just that way and problem is on Southbridge (mobo had toubles recognize HD), dont know if reflow or give up
            • cheapie
              null
              • Jul 2010
              • 849
              Yes... Judging by some of your other posts, it sounds like you have a fried SB.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                May be a shorting socket pin, with it being a 775.....
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Logistics
                  • Apr 2007
                  • 721
                  Dude, my Asus 775 board had this issue a few times; suddenly I get no post. Then, after examining things, i pop out the CPU and find a contact or two look oxidized. Clean and replace always fixed it.
                  By the way, there was no mention of the OP's power supply. If the board was freezing, it may have had bad caps, but sometimes the power supply caps going bad in turn cause yhe motherboard caps to fail. Now, that he has fresh caps on the board, the PSU might be laughing at the prospect of adequately firing up his new, low-impedance caps.
                  Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5039
                    • New Zealand
                    Could be you damaged the board perhaps?
                    -David VanHorn
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      What brand and model of power supply are you using. There is no way you should be getting 10.8V on those input caps since they are connected to the 12V rail. If that really is the case, you may have a weak or bad PSU.
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
                      • black6host
                        Replacement caps for Samson Resolv studio monitor 65A Amp board.
                        by black6host
                        Good day!
                        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                        I'm going to replace the caps and I'll be the first...
                        02-06-2024, 08:22 PM
