Albatron px865pe pro II, new problem, electrician help
  • smokinkane
    • Feb 2006
    • 22
    I sold my Albatron px865pe pro II, to a coworker. I had recapped the board once, with panny fm's, and all is in working order or so they seem. So now the coworker brings me the computer, it doesn't finish the POST. It has a voice genie bios that states "the cpu may have a problem." I have verified that the cpu is in working order, I have cleared the cmos, removed the board, and made sure all caps where secure to no avail. I did get it to post once with a different cpu, then I turned it off. After that it never posted with that cpu or any other again. I need to know if there is a way to volt meter the vrm's, I don't know how to do it. I have a dmm, so if somebody can tell me a way to electrically check the whole board, I would appreciate it.
  • davmax
    • Dec 2005
    • 899
    Re: Albatron px865pe pro II, new problem, electrician help
    First check your power supply voltages. If you have a tower lay it on its side to make the task easier.
    The black wire is common, DMM negative lead.
    Red = + 5V, Yellow = +12V, Orange = +3.3V, White = -5V, Blue = -12V, Violet = 5VSB. Check for reasonable tolerance should be less than 10% error. Check for fluctuations all should be steady. If any wide variation you need to check the power supply capacitors. If the capacitors are of doubtful origin (bad cap brands) they should be changed even if there is no obvious external problem. Or try another power supply.
    The VRM voltage can be checked by placing the DMM negative lead on a motherboard mounting screw and apply the positive lead the centre leads of the MOSFET switches(or better the metal tab on the opposite side to the leads). I am assuming these are accessible. If covered with a heat sink you will need to carefully probe the circuit tracks close to the output capacoitors near the CPU. You should find a voltage between 1.4 and 2.0 volts depending on the CPU type. You really need to know what is required for your CPU.
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
    • gonzo0815
      • Feb 2006
      • 1600
      check the 5v sb caps in the psu for bulging.
      Can you provide some pics from the board? not shure about it, but many new boarddesings require ultra low esr caps, wich the panasonic FM`s aren`t.
      • japlytic
        • Oct 2005
        • 2086
        I experienced this problem, and it was fixed my simply removing and reinserting the ATX12V connector to the mainboard. Too bad it could not say "ATX12V is not connected".
        • davmax
          • Dec 2005
          • 899
          Whilst on the subject of connectors.
          Just lately I have had a number of computers with poor, intermittent or even non existent connection in those four way power connectors that plug into the hard drives and optical drives. The female part of the connection expands making connection unreliable. Use something like a jewellers screw driver to bend the connector split tube inward and creat a better contact.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • Rainbow
            • Aug 2005
            • 1371
            That's common problem, especially with cheap PSUs. A bad connector on hard drive can damage it.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • SDNarcia
              Dell 15R-5521 keyboard problem (KBC?)
              by SDNarcia
              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
              As additional information,...
              07-20-2024, 10:47 PM
