I sold my Albatron px865pe pro II, to a coworker. I had recapped the board once, with panny fm's, and all is in working order or so they seem. So now the coworker brings me the computer, it doesn't finish the POST. It has a voice genie bios that states "the cpu may have a problem." I have verified that the cpu is in working order, I have cleared the cmos, removed the board, and made sure all caps where secure to no avail. I did get it to post once with a different cpu, then I turned it off. After that it never posted with that cpu or any other again. I need to know if there is a way to volt meter the vrm's, I don't know how to do it. I have a dmm, so if somebody can tell me a way to electrically check the whole board, I would appreciate it.
Albatron px865pe pro II, new problem, electrician help
Tags: None
Re: Albatron px865pe pro II, new problem, electrician help
First check your power supply voltages. If you have a tower lay it on its side to make the task easier.
The black wire is common, DMM negative lead.
Red = + 5V, Yellow = +12V, Orange = +3.3V, White = -5V, Blue = -12V, Violet = 5VSB. Check for reasonable tolerance should be less than 10% error. Check for fluctuations all should be steady. If any wide variation you need to check the power supply capacitors. If the capacitors are of doubtful origin (bad cap brands) they should be changed even if there is no obvious external problem. Or try another power supply.
The VRM voltage can be checked by placing the DMM negative lead on a motherboard mounting screw and apply the positive lead the centre leads of the MOSFET switches(or better the metal tab on the opposite side to the leads). I am assuming these are accessible. If covered with a heat sink you will need to carefully probe the circuit tracks close to the output capacoitors near the CPU. You should find a voltage between 1.4 and 2.0 volts depending on the CPU type. You really need to know what is required for your CPU.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
Samsung 18x DVD writer
33 way card reader
Windows XP Pro SP3
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanks -
check the 5v sb caps in the psu for bulging.
Can you provide some pics from the board? not shure about it, but many new boarddesings require ultra low esr caps, wich the panasonic FM`s aren`t.Comment
I experienced this problem, and it was fixed my simply removing and reinserting the ATX12V connector to the mainboard. Too bad it could not say "ATX12V is not connected".Originally posted by smokinkaneIt has a voice genie bios that states "the cpu may have a problem."My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Whilst on the subject of connectors.
Just lately I have had a number of computers with poor, intermittent or even non existent connection in those four way power connectors that plug into the hard drives and optical drives. The female part of the connection expands making connection unreliable. Use something like a jewellers screw driver to bend the connector split tube inward and creat a better contact.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
Nvidia 8500GT 256Mb
33 way card reader
Windows XP Pro SP3
HP Officejet Pro K5300 with refillable tanksComment
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... -
by lazaro.089Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
CPU: Core i9-12900H
Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and... - Loading...
