VGA unknown bad caps help!
  • TheCondor
    • Mar 2013
    • italy
    Sorry guys, i'm new in the forum and first of all i want say "sorry for my bad english". Now let's move to the problem:
    i've recycle a broken nvidia GTX 460 that has for sure bad capacitors, probably also other trouble but i just want try to change all the caps (the pc starts but nothing appear and after about 20 seconds reboot and repeat).
    Anyway i've already done a reflow so i'm trying with the capacitor, if works -good- if not -go to trash-
    The capacitors are shown in the picture attached, where i can find a generic capacitor for the changing? R30 and 042R what are meaning?!
    Thanks in advance for your help!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: VGA unknown bad caps help!
    042R means nothing useful - it is a factory code.
    Those caps are 820uf 2.5v
    I dont know about the R30 what is the board designation is it C?? L?? R?? F??
    • TheCondor
      • Mar 2013
      • italy
      Thanks for the really istant reply. Let you know the designation tomorrow when i will have the card in my hands.
      • mariushm
        • May 2011
        • 3799
        The ones at the top are 330uF 16v, the ones at the bottom 820uF 2.5v
        They're all polymer capacitors, which are kind of expensive but you probably can't do much about it, as the heatsink above would not allow you to replace them with electrolytic capacitors - you'd probably have to use 1200-1500uF 6.3-10v capacitors to get close to the same specs, and those are tall.
        I can't tell who makes these polymer capacitors, the color and the codes are not familiar to me.
        This page: http://capacitor.web.fc2.com/solidcapacitor.html shows them as uncertain, only mentioning similar polymers were noticed on a Biostar motherboard (scroll all the way to the bottom of the page).
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Its ok I found a pic of a similar board - must be a different version it
          is meant to be a GTX 460 but is a lot different.
          Anyway the R30 has an L designator which means it is an Inductor.
          They do not often fail and when they do they tend to burn up.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            were the caps like this before you did the reflow?
            polys usually do not bloat, they usually explode
            measure them, find some nichicon OS-con polys available in your country and replace
            • tmiha71
              • Apr 2010
              • 130
              This card has Thermal Designed Power (TDP) of 150W, I do not think you'll be lucky, only 4 inductors (4 phase ??), and only 6 poly caps...
              Compare it to motherboard (CPU), 4 phase and 6 poly's, they are usually advertized for max 95 W...
              And OS-CON are WAYYYYY underspecd for this monster (ripple current for sure, and probably ESR too), it'll be like replacing Rubycon MBZ with Yageo SC ...
              And if you did The oven thing, you fried capacitors and probably inductors too (if they were not removed before)...
              • TheCondor
                • Mar 2013
                • italy
                Thanks guys, this forum is very useful and populated of competent guys!
                Caps before oven thing was apparenty good, i covered it before putting in the oven but nothing... i'll try to replace the 820uF and 330uF with some found on some broken mainboards (highter voltage but same capacity). Last chance or i'll trash it.
                • c_hegge
                  • Sep 2009
                  • 5219
                  That may not work if you replace them with electrolytics of the same value.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Probably Lelon OCRZs. And it looks like they're as bad as FZ!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Huh? Those look nothing like OCRZ. Lelon polies always have the series name on them, so the 1st line would be "OCRZ"
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
