Matrix-hd7970-3gd5 death
  • manotari
    • Mar 2013
    • España
    Hello, I have a VGA to put it on the PC, leaving it dead, will not start.
    I've found that I had a capacitor backwards, I placed well but still the same. Now I'm looking for a new capacitor to discard.
    Could have charged more?
    This is the photo of the capacitor appears backwards.
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Re: Matrix-hd7970-3gd5 death
    It APPEARS backwards, but is it really? Check for markings on the board. And if it really was backwards, then somehting might be blown. Also, it might be a gpu issue. Those caps are polymers and probably al good, because the dont go bad very easily
    I can put text here?!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      its an asus board, motherboard or vga board, they mark everything on the positive side, so yes, it is backwards
      its actually a Functional Polymer, which stands a higher chance of dying than a full blown polymer in the case of a umm well just call it 'reverse polarity incident', actually I see a slight shadowing on the top which means it might have a slight bloat. Solids don't usually bloat they usually pop, but this is an FP and some of that pressure might of been released through the bottom
      its hard to tell what series it is, cause of the convoluted way nichicon marks the FP-CAP series, but its 270uf 16v, thats about all I can tell you
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        I have been looking for a fuse but cant see one. However i notice that you have an excess of thermal paste -(use a rice grain size blob only) - anyway it is on several of the components and unless it is totally non conductive (electrical) it will be shorting them out.
        Clean off with Isopropyl alcohol.
        • rogfanther
          • Jul 2006
          • 458
          • Brazil
          Also, what is the history of the board ? Was it recapped, stopped working, what else ?
          • tmiha71
            • Apr 2010
            • 130
            Even less will do the job, half or even a quarter (of size of rice grain) will be enough (at lest did job on CPU's)...
            • mariushm
              • May 2011
              • 3799
              PCE101 is soldered incorrectly. Look at all the other capacitors, that PCE101 is the only one backwards.
              After desoldering it, make sure it's not shorted before soldering it the right way. But you should just replace it with a new polymer capacitor instead.
              Get some isopropyl alcohol and remove the excess paste that touches those resistor networks near the gpu chip.
              Otherwise, there's nothing obviously broken on the card. Measure voltages on the capacitors when board runs and go from there.
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
