MSI MS-6337, bad caps...
  • RoadKill
    • Jun 2004
    • 49
    Gah, I found about all this by chance, I was reading an article an Anandtech and saw a side column, a forum post about somebody's USB ports failing, dunno what made me click it, but I did, and after reading through, found links to badcaps and ventured further into the bad capacitor fiasco, I've become somewhat paranoid
    I tried to look at the caps on my own main PC (an MSI Mega PC) but could see no branding and no bloating (but I saw very few, since it's cramped to hell)... this relieved me a bit..
    Then I thought of my second PC, a Celeron 1Ghz @ 1.45Ghz (fucking beautiful overclock) on an MSI MS-6337 socket 370 board.
    Had a quick peek, thought I saw bloating. Aww, crap, took the PSU off to see the board underneath, and my worst fears were confirmed. Shitty, bloated caps and some electrolyte leakage. >_<
    The only symptom I've really had was the fact the other day, it randomnly reverted back to 1Ghz stock clock speed for no apparent reason. It's not been the most stable system recently but I've had no real major problems with it, and it was always a quick machine when it was my main one. *sigh*
    Couldn't see any branding on the caps, but they look like generic cheap trash (and obviously are).
    I live in the UK, and have absolutely no money right now, and I would not actually want to use the PC again with the caps in this condition.
    I don't want to buy a new PC incase it has bad caps now, and I suspect everything of having them (I even pulled apart my new ADSL router to inspect it's caps, XD)...
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Welcome to the boards.... I've had large boxes full of MS-6337's sent to me for recapping. They're a common fixture around here. If yours are showing the typical bloating, I'd stop using the system until they can be replaced. If one shorts, it can cause severe damage and even destroy the motherboard and perifs... Time to break out the soldering iron!
    On a side note, I always thought Abit was hit hardest by the crap cap plague, but I believe now that MSI was the worst.... I still see a LOT of Abit boards, however, I see far more MSI's... They even got their own dedicated section here in the forums...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • RoadKill
      • Jun 2004
      • 49
      Just thought I'd bump this thread again, old school style..
      I still haven't recapped this board, I'm terminally lazy. It's still on top of my parents fridge freezer at home, in a bag, with a whole bunch of brand new Rubycons waiting to go on it.
      I just never got round to it, I guess. My soldering skills were never great.
      Shame. It'd make a nice server now...
      • bushytails
        Moderator
        • Dec 2004
        • 217
        You're welcome to send the board and the caps to me, if you don't want it anymore.
        --Randy
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          that was the first board i recapped. It is a perfect candidate for recapping because :
          A) the solder pads around the holes are big, makes it easy.
          B) the holes themselves are huge, they clean up great
          C) you can place 10mm caps everywhere without probs except for the two together below the northbridge
          D) it is a very well manufactured board (except for the caps). When it was new I thought damn that is a good looking board.
          E) there are not too many caps and you replace all except the mini ones so the board is gonna be ultra stable when you are done.
          my board
          https://www.badcaps.net/forum/viewtopic.php?t=96
          see if you can get it done faster than i did. took just over 1 year to get around to doing it. what is it with these boards
          • RoadKill
            • Jun 2004
            • 49
            Haha, well, lets see, it was June 15th 2004 when I posted that, so I've got a while before it hits a year
            It is a nice board though, kudos to MSI, it overclocked so well, and you could control all the fans using standard speedfan software on the machine, it's a nice board.
            I can't understand why they used such poor caps, well, I can, but it's a shame.
            Before I knew about the badcaps phenomenon, I had a friend with the same board, and his PSU blew, I was like, oh, okay. Tried his board with a diff PSU, wouldn't power up. PSU now dead.
            Did it AGAIN, with another PSU, PSU dead.
            I didn't know about badcaps at the time, so I didn't notice, but I'm near as damn 100% sure that his caps had shorted out and were screwing every PSU that touched that damn board.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: MSI MS-6337, bad caps...
              If the power supply fails to power up afterwards, then look for a fuse inside the power supply. That fuse likely blew. PC power supplies, believe it or not, have a capsule-shaped glass fuse. It possibly is replaceable.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Rainbow
                • Aug 2005
                • 1375
                I've recapped many of these MS-6337s too (most of them v5 for Tualatins). They are really easy to do. You maybe won't believe but I have one and it has still good original caps
                When a PSU is shorted, sometimes a diode (one of the dual-diodes in 3-pin packages on heatsink) inside gets shorted too - so it's shorted internally and can't be powered up. Or one of the two main switching transistors can go bad (on the other heatsink). The fuse blows only when there's a short on the primary side - shorted switching transistor, rectifier or failure in the aux. power circuit (ATX PSUs only).
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
                • black6host
                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                  by black6host
                  Good day!
                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                  I'm going to replace the caps and I'll be the first...
                  02-06-2024, 08:22 PM
