Hi All,
I'm looking to do a retro PC build, using an ABIT BP6 which I recently had shipped from the UK to Australia for $55AUD with 2x Celeron 433's included.(I really wanted one)
Even though the mainboard is fully functional and seems stable at the moment (surprisingly), I've decided to re-cap it anyway so I would like to confirm which caps I should buy.
On this post it says the following:
However on the online store it shows the premade kit as containing:
As you can see, there is a fair difference between the two, and I want to get this right first go as these boards are very hard to find in good condition.
I haven't ruled out performing the coppermine mods at this stage, but initially I'd like to get it refreshed first.
Cheers in advance...
				This is what your kit will contain to successfully rebuild your Abit BP6 Mainboard.
The kit contains 25 capacitors, itemized as follows:
Quantity Value Voltage Diameter
12 1500uF 6.3v or 10v 8mm
12 1000uF 6.3v or 10v 8mm
1 470uF 16v 8mm
The 470uF caps is for the EC10 mod, replacing the 100uF cap.
1 470uF 16v 8mm
