Abit BP6 recapping & stability tips [UPDATED]
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Ok, Ive had several emails and even a posting or two in the forums about the Abit BP6 motherboard... Along with the VP6, I've had a lot of experience with the BP6. As we all know, the BP6 was plagued with the crap cap problem as well... However, this board has room for a couple variations in changing out the caps. I usually try to sway people away from changing capacitance values, however, through MUCH testing and experimenting with this board, some mods were worth doing.
    I'm sure that all the BP6 users are familliar with bp6.com, and they've given me quite a few usefil tips, but their site is a MESS to dig through looking for info. The tips here are very simple and to the point if you want a stable BP6 again.
    It doesn't really matter which revision you have, as the mods will cover both revisions.
    Here's a list of the problem caps and what to replace them with.
    The following capacitors stock are 1500uF 6.3v caps. Replace them with 2200uF 6.3v or 10v capacitors. Use only LOW ESR caps!! This is VERY important!
    EC15, EC5, EC1, EC11, EC4, EC6, EC9, EC7, EC8, EC2, EC13, EC14.
    Ok, EC10 needs to be replaced with a 1500uF 10v capacitor.
    These caps need to be left at their stock values of 1000uF 10v caps.
    EC3, EC17, EC25, EC21, EC20, EC24, EC18, EC19, EC22, EC23, EC28, EC31.
    It is also recommended that some thermal grease be applied to the northbridge heatsink... You know that old BX chipset and how hot it can get!!
    I'm not going to go into any Coppermine modding, simply because it's risky business! I have successfully completed it on a few BP6's, but I also hosed a couple boards in the curve....
    The cap replacements above were found to be the BEST for reliability running stock, overclocked, and even Coppermine mods. If you plan on recapping your BP6 and have any questions, let me know!
    Good Luck!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ncdave
    • Oct 2003
    • 33
    Where does one find low-ESR 2200uF or larger caps in an 8mm can?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Ohhh.... Umm... Dave, you're gonna love this one...
      I've only found TWO places that I can get 8mm caps from, and one of them is Jackcon... While they don't traditionally sell to the consumer, they can be sweet talked... The second is Digikey (www.digikey.com)... The only problem with them is cost!! Their 8mm low ESR caps are almost a buck a piece!! OUCH!
      Honestly, on the BP6, I've always used 10mm caps. They will fit properly with a little ingenuity, and look stock, not like Mickey Mouse recapped the board.
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i prefer the panasonics that digikey has.
        more expensive but i hate having a repair job come back like a boomerang.i am still seeing bad jackcon caps in boards with 2002 dates.
        not seen a repeat failure yet.
        i will post the digikey part numbers when i get to the shop in the morning.(if roadrunner is back up)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          OHHHH WERE THOSE THE DAYS!!!!
          I sold my last BP6 about 5 months ago, running 2x Celery 366's @ 550/100, 2.2v core, OCZ heatsinks... I actually miss that system...
          I have a parts BP6 still here, as a matter of fact, ncdave of our forum got the VRM toroid coils out of it...
          Overclocking just hasn't been the same since the BP6!!
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            BP6 recapping using 10mm caps
            Ok, as mentioned above, the hunt for 8mm replacement caps is a difficult persuit... They're nearly impossible to acquire from a reputable manufacturer. I have added a couple pictures of a BP6 I recapped using all 10mm Nichicon and Sanyo capacitors. Doing this takes a little more finesse to make it look pretty like the example below, but it is really easy!!
            The only issue with using 10mm caps on this board is the spacing around the CPU sockets. This is an issue with the original 8mm caps also. This was a blunder on Abit's part, placing the caps in such close proximity to the sockets. This inhibits the use of monsterous coolers. Although, this was an issue before with the original caps, the 10mm caps just make things a little tighter. However, all retail Intel Celeron coolers fit with no problems, and so do the nice ThermalTake copper Golden Orb heatsinks.
            If you have any questions, feel free to post them!
            Team : 49813
            Join in!!
            Team Stats
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              do you still have the carcass?
              why was it scrapped?
              i may need one to pick parts from
              i finally got one thats is more than caps.
              all voltages normal,clock running but no post no beeps.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Yes, I still have a BP6 carcass... It's plundered pretty bad though... I PM'd ya.
                Team : 49813
                Join in!!
                Team Stats
                • benwaterson
                  Gigabyte Aorus 1080ti - card not initialising
                  by benwaterson
                  Hi there.
                  Have searched various forums but haven't come across the exact issue I am having.
                  Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                  I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                  Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                  02-05-2022, 11:42 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • corrize
                  Quality solder iron tips and Kapton ?
                  by corrize
                  Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
                  I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
                  Do you have brand of qually tips pls ?
                  Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
                  05-24-2021, 11:35 PM
                • frankr2994
                  Dell T5810 bios mods, motherboard mods, schematic help
                  by frankr2994
                  Hello all. Hoping this is the right section to post and I have 3 questions that any one of them answered should fix me up. So I have a Dell precision T5810 with an E5-1650v3 cpu. I've been overclocking it using throttle stop. I'm at my TDP limit of 140 watts and I can't get past it. Where I'm at right now is in order from best solution to worst.
                  1 I need an unlocked bios. I have all the ami bios tools and a spi programmer. I've tried modding it and a couple of people from bios mods and win raid tried modding. I can't get any other menus to show up. If someone can successfully mod my bios...
                  02-22-2022, 07:39 PM
                • ignacio.ino27
                  (BIOS) Asus X541UVK Rev 2.0. Stock ME REGION
                  by ignacio.ino27
                  I share with us this binnary file that i have edited the ME Region (from original dump version to stock 11.6.0.1126).
                  It is "stock" region and working.
                  BIOS: X541UAK.306
                  MOTHERBOAD: X541UVK Rev. 2.0
                  CPU: Intel Core i3 7100U Kaby-Lake R
                  ║ Family │ CSE ME ║
                  06-08-2021, 05:39 PM
