I need suggestions for replacement of a 1500uf 6.3v cap which is larger in diameter than the other similar caps on the board. Perhaps one of the polymers would work?
AOpen AX4BS Pro
Re: AOpen AX4BS Pro
This is one of the highest rated electrolytic 1500uf cap out there:
https://www.badcaps.net/store/produc...roducts_id=139
There's also an 8mm 6.3V version stocked, but it seems to me that the silkscreening there indicates clearance for either an 8mm or 10mm cap.
If you want a polymer cap, this is backordered:
https://www.badcaps.net/store/produc...roducts_id=134
Only in 10mm though."We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
-Leonid Brezhnev (On the Yom Kippur War) -
Re: AOpen AX4BS Pro
Those polies have been on backorder for months now. I'd just go with a lyticI love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
by qwerty99Hello!
I need to change the capacitors on my three original Xboxes.
Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t... -
by bigbearkI have an Asus P5GV-MX that uses 2 KZG 1000uf 16V in the VRM circuit.
I also have a Gigabyte GA-8IPE1000 that has 3 KZG 1500uf 1I6V in the VRM circuit.
I tested both these boards with a working Sata HDD and neither of them will start the O/S.
They both boot fine and show the MX Linux first screen. When I press Enter to start the O/S, they hang with a blinking cursor on a blank screen.
If I select the option that shows the detailed loading steps, it shows 2 lines, last of which is "loading Ramdisk" after which the same blinking... -
by DannyxGood day folks. Some of you may recall that a while ago I was struggling to put together what I considered to be a very basic automation for a water supply system. It didn't work out the way I intended and I learned my lesson to do it properly from the start, rather than try to reinvent the wheel and patch something together myself from scratch, so I'll stick to commercial alternatives for future projects and such a project just came in today !
This one is easier simply because this time the pump and level sensors are in the same place, so they don't require a remote connection.... -
by mon2Hi. I think we have a candidate for our first DFU macbook with a 'critical update error' message (A1706).
With regret, we do not seem to have a machine to mate to a suitable host to run the Configurator 2 tool.
Any suggestions on such a box ? The latest models are quite expensive on Ebay and such.
We do have a macbook with the older style Thunderbolt connector - can we purchase a Thunderbolt to USB C cable and run the same tool ?
The system details does show a THUNDERBOLT controller on this other macbook.
Does the host need to have... -
by shakib200Model : Dell E7240 ( LA-9431p)
All coils ok.. No short
When injecting voltage supporting charging ic CD3301B ic is heating.
After replacing new cd3301b ic, the new ic is also heating.
*** This attached image is for reference.... - Loading...
