Suggestions for machine for Apple Configurator 2
  • mon2
    • 13940
    Hi. I think we have a candidate for our first DFU macbook with a 'critical update error' message (A1706).
    With regret, we do not seem to have a machine to mate to a suitable host to run the Configurator 2 tool.
    Any suggestions on such a box ? The latest models are quite expensive on Ebay and such.
    We do have a macbook with the older style Thunderbolt connector - can we purchase a Thunderbolt to USB C cable and run the same tool ?
    The system details does show a THUNDERBOLT controller on this other macbook.
    Does the host need to have a T2 chip to run the Configurator 2 tool ?
    Can a current (year?) iMAC be used as the host ?
    Should the host show 'DFU' text if the target is truly in the DFU mode ? Saw that on some youtube videos.
    Welcome comments.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Suggestions for machine for Apple Configurator 2
    https://logi.wiki/index.php/Critical...roubleshooting
    • mon2
      • 13940
      @piernov - thanks. We have been on this webpage and also on repairwiki.
      We do not believe to have a valid machine to act as the host.
      Any recommendations on an 'affordable' machine that can support the Configurator 2 tool?
      Our A1534 (single USB C; 2016) machine does not offer a thunderbolt controller and the tool states 'Cannot use thunderbolt accesory. Thunderbolt accesories are not supported on this mac'.
      • piernov
        • Jan 2016
        • 4435
        • France
        A1706 does not have T2.
        • mon2
          • 13940
          Yes. Agreed. But we suspect that the BridgeOS is corrupt on the A1706.
          How to fix it?
          Need to run configurator 2 on another machine. This other machine will be the host.
          What are the minimum (lowest cost) requirements to fix the A1706 target?
          Does the host need to be a T2 machine to run configurator 2 tool?
          • piernov
            • Jan 2016
            • 4435
            • France
            DFU recovery is for T2/M1 only.
            • mon2
              • 13940
              Ok. Well noted. Will review the logic board for other faults. Thanks!!
              • Simplebeans
                • Sep 2021
                • 130
                Hey mon2, hope you are well. If your aiming to use Apple Configurator for a Revive or restore for an Intel-based Mac which contains the T2 Security Chip then see this page for all the compatable devices:
                https://support.apple.com/en-om/guid...debea5be51/mac
                And to use Apple Configurator for a Revive or restore on a Mac with Apple silicon then see this page for all the compatable devices:
                https://support.apple.com/en-gb/guid...dd5f3c75ad/mac
                The T2 Security Chip is powered by bridgeOS. The A1706 macbook pro contains the Apple T1 SoC instead which is powered by embedded OS (eOS).
                • RWS93
                  Apple A1990 / Board number: 820-01041
                  by RWS93
                  Brand: Apple
                  Model: A1990
                  Problem: I am not an Apple kind of guy to start with. But I am quite experienced with motherboard repairs in general. So the laptop is stuck with 5v 0.250A and does not negotiate 20v. Same symptom on all 4 USB C ports. When charger is plugged the amps start at around 0.060 then go trough: 0.100 - 0.180 - 0.230 - 0.244 and stay like this. Laptop responds to the power button: once I hold it long enough current goes down to 0.060A and then up to previous levels.
                  Board clean, no liquid damage, no corrosion....
                  04-11-2024, 03:43 PM
                • a_p3rson
                  Apple Watch Charging Controller Schematics / Boardview - 820-02601
                  by a_p3rson
                  Hi there,
                  I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                  You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                  This daughterboard uses an interesting...
                  04-21-2025, 11:41 PM
                • myth77
                  a1466 to a2141 apple configurator
                  by myth77
                  I am having issue with macbook pro a2141, 2019. It start with question mark, the only option is internet recovery but it will not go to disk utility mode..just stops on like 1/3 progress bar with apple logo.
                  When i insert usb disk it will not recognize it, but on usb ports it is giving picture on external screen. It is heating a lot.
                  I did all resets and only thing left is try to revive it (firmware reinstall) with apple configurator from another mac. I have only macbook air 1466 from 2013. I install apple configurator on macbook air but when i connect usb-c (mac 2019) to usb-a...
                  08-28-2022, 12:26 PM
                • bobotheklown
                  Nerdtool Apple display angle sensor configurator bypass
                  by bobotheklown
                  Does anybody have one of these yet? It looks like it just has a $5 esp32-c3 processor and then a few resistors and other components..Probably $10 to get pcbway to print it out, but I need access to the firmware and haven't been able to find it anywhere online. This allows individual users to perform screen repairs on apple laptops by avoiding the need to use apple parts (and thereby gaining acces to their configuration utility) and retain the open/lcosed sensor capability for the screen. I'll post the circut board files here if I can get a copy of firmware, no point in doing the work until I have...
                  04-06-2025, 01:01 AM
                • volinakis
                  Apple Configurator 2 V2.13 for Big Sur
                  by volinakis
                  Hi, please share a old version of Apple Configurator 2 such as V2.13 to work on Big Sur. Thank you.
                  07-13-2023, 09:51 AM
