Asus P4C800-E Deluxe
  • kletro
    • Jan 2011
    • 9
    I have an Asus P4C800-E Deluxe I need some help with. This board works and will run a live CD.
    However if it is restarted with the reset button or ctl+alt+del it will not POST. If I go into the BIOS and exit, after it restarts it will not POST. And usually but not always, shutting it down and restarting it will not POST.
    If I clear the CMOS it will start again and run with no problems. All the caps look good though they are mostly OST.
    I have tried flashing the BIOS to different Asus versions using the latest aufdos, all with the same results.
    Is it the BIOS chip? What do you think?
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • lrouw84
    by lrouw84
    Hi there,
    01-28-2023, 01:31 PM
