Problems with VP6
  • Parch
    • Aug 2006
    Problems with VP6
    I am having problems with my vp6
    does not boot all the time
    freezes up after awhile when it does boot
    thought it was the cpu's they were both 933's but not matched
    so i bought two 1.0 ghz
    samething
    swapped ram,video card,hard drive
    samething
    caps seem to look ok judging by the pic's on here
    any ideas's would be very helpful
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2662
    • oooo ess aaaaaaaaa
    Re: Problems with VP6
    if it were me, I would replace the caps anyway. i had the same symptoms as you and my caps "looked" good as well. after a bit a couple caps started to bulge, but if I would have replaced them when I first started having problems, it would have saved me a lot of headaches. at the same time, I put in a bigger PSU (Antec Trupower 430 I believe).
    after that, all was right with the world and its been running great ever since......and that was 5+ years ago.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i have seen 50+ vp6 with stability issues that total recap fixed.
      the black/gold jackcons in the vrm section often fail without bulging.
      i have one on the bench now that came in with a bootlooping complaint that the caps look fine on.but the scope shows 1.5v p-p of trash on vcore!
      its worth fixing.
      tc or i can do it if you want it done.
      edit...
      i see you have not swapped the power supply.they can also cause this.still should be recapped asap though.
      • estabilito
        Swapped CPU from Fujitsu to Dell - boot guard?
        by estabilito
        Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
        05-27-2025, 05:26 PM
      • privato89
        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
        by privato89
        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
        Let's begin:
        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
        03-26-2024, 06:37 AM
      • Luke Anders
        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
        by Luke Anders
        A few details about the laptop itself:
        Name: Lenovo Legion 5
        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
        BIOS Version: GKCN60WW
        EC Version: GKEC65WW
        Serial Number: PF39AQ7Z
        Board Model: NM-D562 Rev 3.0
        RAM: 16GB Installed, DDR4 (brand new)
        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
        I bought this laptop recently from eBay as a faulty device....
        10-12-2024, 05:13 AM
      • hinisa
        Xiaomi router freezes at boot after re-capping
        by hinisa
        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
        07-08-2023, 05:58 AM
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
