Mystery beep code a7v8x-x
  • fed32169
    • Aug 2006
    I've looked far and wide for an explanation of the beep code for my problem board, an asus a7v8x-x (which I got cheap on ebay and would love to get cranked up). The only time it stops its incessant bleating is when you don't have a processor in it. 2 seconds on .5 sec. off, unless you put mem in it, then it waits about .75 seconds to start beeping, and continues at the normal 2/.5 rate ad nauseum, variation free. The asus power light works perfectly it seems, as do all the fan connectors. I've a new box with 400w supply, the only thing I don't like about that is it shows 4.88v on the 5v supply line in the bios of another problem prone board (that I've already ordered replacements from badcaps for, though I wait and wait for them); I think I'll test that psu thoroughly tomorrow by hand, but I also think it will be fine, or at least within the usable range.
    The caps do not look bad; the 3300's in the vrm group are a chemi-con brand (kmg or something), but the rest (about 15 in 2 sizes, very small for their ratings) are "ost", which I understand are generally just crap.
    I get the feeling this board has some hope of life in it, but then again it could be I sense its desire to experience the afterlife instead.
    Any help, eh? PLEEEEEEZE?
    Thanks in advance, Steve.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Mystery beep code a7v8x-x
    Replace all the OSTs; they often fail silently without bulging. Chemicon KMG is a standard temperature (85c) GP cap - it's probably OK at the VRM input and a few other low-ripple bypass locations, but not at the VRM output or in any hot zone near the CPU. In particular, replace all the caps near the Northbridge and memory DIMMs - bad caps there will cause memory read/write errors, which can cause a whole range of symptoms of general flakiness.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      The Chemicon caps probably are KZE. Also, these motherboards are tough.
      These motherboards are hard to kill, AFAIK. I OC'ed a lot with my A7V8X-X.
      The only problems is the lack of a PCI and AGP lock. That justs means that you can't get the FSB beyond approximately 175 mhz without losing stability.
      Because of the fact that it lacks a PCI and AGP lock, most people don't like these motherboards.
      Because of the repeated bleeping, it's now time to reset the CMOS.
      The settings probably are wrong when an A7V8X-X fails to POST.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • fed32169
        • Aug 2006
        Thanks for that, but I already tried that, to no avail, fresh battery also.
        My guess is something wrong(guess)with power distro on the board, but the weird thing is the power light works flawlessly.
        There seem to be alot of caps on the board, so it's an expensive proposition to fix it and then find it doa anyway due to a fried northbridge or something, but its a chance I'm willing to take, moreso now that you've given me a heads up about the durability thing.
        Could be the result of a bad flash (and I don't have any rig set up for this bios chip to swap out and reflash). In fact its likely as the guy who sold it to me said he bought it @ an auction of a computer store gone under.
        Anyway, it's next to solve on my plate, & I thank you all for your input and any more you might be able to generate!!
        Happy Cappin'!Steve Wallace fed32169@comcast.net
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          try known good ram.
          often the single long beep is bad ram.
          and ANY change REQUIRES a cmos reset.
          i see a lot of no post issues on a7 boards that are resolved by clearing cmos.
          • moddolicous
            • Jul 2006
            • 18
            If you know what type of bios it is use this page to help find out why its beeping:
            http://www.amptron.com/html/bios.beepcodes.html
              LCD LED TV Service Menu Codes
              TCL LED TV Service Menu Code
              LG LED TV Service Menu Code
              10-31-2024, 03:58 AM
            • tech_guru
              Dell Inspiron 15-3521, 5 Beep Code - No Picture
              by tech_guru
              Hello.
              I have a problem with this laptop DELL INSPIRON 15-3521 (Motherboard VAW01 LA-9101P REV 1.0).
              At first it came with 1 beep code continuously and no picture. I flashed the bios with programmer and it turned on but now some times, not always, it does not turn on and gives 5 beep code, which Dell states it is Real Time Clock Power Failure. The cmos battery is new. If it boots up correctly, it stays on and works perfectly.
              Do we have any idea what it could be or where to start diagnosing? I have schematics and boardview.
              Thank you.
              07-08-2022, 07:40 AM
            • McKey
              Yoga 370 with error beep code: 0284
              by McKey
              I saved the bios dump (attached), i checked it with uefi tool to get an idea of the cause, but i have no idea what to look for.
              SN:
              MP-184NWU 17/05
              TYPE:
              20JH-002TGE
              LABEL PN:
              SL10N17569
              Motherboard number:
              LA-E292P
              For the future adventurer: Before someone gets confused like me for a second, the bios chip is U49(SPI FLASH 16Mb), do not mistaken it with UT2 (8Mbit Flash)...
              04-24-2025, 08:46 PM
            • bembeno
              Dell 9020 MT no display beep code 1 3 2
              by bembeno
              have dell 9020 mt - motherboard E93839 AM0426 service tag : GS2LR12 - power on but not displaying with beep 1-3-2 i check the ram slot volts 1.5 - 0.75 - 3.3 on pin 236 are oki flashed the two bios chips with defferent files last time with clean me and still the same issue
              12-26-2023, 02:45 PM
            • musanide
              Cedar 13269-1 7 beep code
              by musanide
              good day all, i have a dell 3542 with 7 beep code. most of the common voltages are available, but am getting 7 beeps. Any ideas or solutions will be appreciated......
              08-12-2022, 12:03 PM
