Cedar 13269-1 7 beep code
  • musanide
    JQUB
    • May 2020
    • 86
    • zambia
    good day all, i have a dell 3542 with 7 beep code. most of the common voltages are available, but am getting 7 beeps. Any ideas or solutions will be appreciated......
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Cedar 13269-1 7 beep code
    Give voltage on all coils. What is the reading on dc supply(after turning on) in these 2 scenario's
    01.With Ram
    02.Without Ram
    Known good clean me bios flashed??
    • musanide
      JQUB
      • May 2020
      • 86
      • zambia
      01.With Ram
      02.Without Ram
      1. bios is ok, have cross checked it,
      2.ram voltages are stable with or without ram, 1.36v
      3.all ram voltages are ok( on the ram slots)
      4.pch voltage and cpu voltagees are ok , and the cpu is getting hot.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I asked for consumption on your dc-supply. Are you powering the mb from adapter??
        Check DRAMRST# on pin30 of ram slot.
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • tech_guru
          Dell Inspiron 15-3521, 5 Beep Code - No Picture
          by tech_guru
          Hello.
          I have a problem with this laptop DELL INSPIRON 15-3521 (Motherboard VAW01 LA-9101P REV 1.0).
          At first it came with 1 beep code continuously and no picture. I flashed the bios with programmer and it turned on but now some times, not always, it does not turn on and gives 5 beep code, which Dell states it is Real Time Clock Power Failure. The cmos battery is new. If it boots up correctly, it stays on and works perfectly.
          Do we have any idea what it could be or where to start diagnosing? I have schematics and boardview.
          Thank you.
          07-08-2022, 07:40 AM
        • McKey
          Yoga 370 with error beep code: 0284
          by McKey
          I saved the bios dump (attached), i checked it with uefi tool to get an idea of the cause, but i have no idea what to look for.
          SN:
          MP-184NWU 17/05
          TYPE:
          20JH-002TGE
          LABEL PN:
          SL10N17569
          Motherboard number:
          LA-E292P
          For the future adventurer: Before someone gets confused like me for a second, the bios chip is U49(SPI FLASH 16Mb), do not mistaken it with UT2 (8Mbit Flash)...
          04-24-2025, 08:46 PM
        • bembeno
          Dell 9020 MT no display beep code 1 3 2
          by bembeno
          have dell 9020 mt - motherboard E93839 AM0426 service tag : GS2LR12 - power on but not displaying with beep 1-3-2 i check the ram slot volts 1.5 - 0.75 - 3.3 on pin 236 are oki flashed the two bios chips with defferent files last time with clean me and still the same issue
          12-26-2023, 02:45 PM
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
