Abit KT7 Questions / Woes
  • -kickstand-
    • Jul 2006
    Hello all,
    I'm posting because I have a question about my KT7. I have had this board since the spring of 2000 and it has been the core of my main machine ever since it's original purchase. Needless to say, this board has seen a lot of usage. I'm really surprised to read that the KT7 was notorious for having capacitor problems because until recently, I have never had any issues from this gem.
    The issue I've encountered began earlier this week; USB devices stopped being detected. The problem is intermittent, but pronounced enough for me to be alarmed. Could this indeed be the start of capacitors going bad? I'd like to know just what is going on before I do my last upgrade on this platform. I've got a x850 XT and Mobile Barton enroute which will serve as the last 'hoorah' for this board before moving to an Intel platform some time down the road.
    When I get home this afternoon I'll part everything out and check the capacitors again. The last time I checked, I found a few bulging, but none were discolored or leaking. Should I take note of which brand of capacitor is being used and where?
    This board has seen me through 6 processors, 4 video cards and 3 cases, so I'd hate to give up on it now. Any help would be greatly appreciated. I'll provide system specs that count for reference:
    Abit KT7 (Non A or Raid with modified BIOS)
    Athlon Thoroughbred B (Mobile with wire modifications)
    Sparkle 430 Watt PSU
    Thx.
  • Rainbow
    • Aug 2005
    • 1375
    Re: Abit KT7 Questions / Woes
    It's probably full of Jackcons. Some of them went bad very soon, some later (like yours).
    • gg1978
      • Dec 2004
      • 431
      I didn't think a mobile Barton would work on a KT7.. I just recapped one myself.. You'd probably be better off with a socket 754 sempron board and CPU, in order to effectively utlilize the X850XT.,..
      • Shroomie
        • Apr 2006
        • 356
        Oh, the mobile Bartons are pretty incredible chips. However, the motherboard probably would be the bottleneck there.
        You know there's something wrong when you open up a PSU and are glad to find Teapos.
        Why I don't buy cheap cases!
        • tazwegion
          • Jun 2006
          • 444
          Well, I've owned 2 Abit KT7's and both unfortunately had clapped out Jackon capacitors, recapping these boards is definitely a worthwhile exercise and I'd strongly recommend that course of action
          I'm curious... have you upgraded the NB cooler at all, the supplied 40mm fan doesn't have an overly long life span, and because there's not much 'meat' in the actual heatsink itself, stability issues with heat can/do result IME
          Viva LA Retro!
          • -kickstand-
            • Jul 2006
            Sorry for the late reply.
            I am in the process of cleaning my components in prepartion for my new CPU and video card and I have not noticed anything out of the ordinary. There is no odd smell, there are no leaking caps, but there are two swollen caps by the DIMM slots which is only noticable when viewing them from a side profile.
            I think it would be advantageous for me to recap the board if for nothing more than ease of mind and longevity. I have a diagram of the capacitors to replace, but I'm not too experienced with an iron. I can repair watches, so precision digits are not the issue, but I would feel more comfortable with the entire process if someone could point me toward a tutorial and maybe even suggest a decent kit to purchase. Also, can I replace the capacitors with those of solid design? I've heard solid capacitors have a better tolerance of heat and provide a more consistant voltage.
            @tazwegion - The northbridge chipset fan began vibrating horribly about 3 years in, so I simply removed the entire assembly all together. I measured the temperature of the chipset using external instruments while the system was under heavy load and was surprised to see the highest temp I could produce was 29C. I made the decision to leave the heatsink and fan off from that point on.
            • Hagis2k
              • Jul 2006
              • 66
              Swollen / Bulging caps are a true sign that you need to replace them...
              • tazwegion
                • Jun 2006
                • 444
                That doesn't seem too high, though I don't know the actual heat tolerance of the NB chip, I never actually measured the temperature of my NB, but I do recall the cooler being quite warm to the touch @ load (I run 24/7 applications), a larger passive chip-sink would provide peace of mind & silence, but I ended up using (meaty) 40mm Gigabyte chipset coolers I acquired very cheaply @ a local PC swap meet
                Viva LA Retro!
                • Foetuss
                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                  by Foetuss
                  Hi all
                  Hope this is in the correct place.
                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                  Could use some double checking to see if I'm not doing something stupid .
                  Pictures of the boards are attached.
                  What I will be replacing with what : (planned)
                  Soltek Golden ::
                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                  01-18-2025, 11:44 AM
                • studdy05
                  Bricked HP Probook 450 G7 Bios questions
                  by studdy05
                  Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                  Ive got...
                  07-08-2025, 09:24 PM
                • electronx
                  Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                  by electronx
                  I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                  1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                  According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                  If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                  06-26-2025, 03:27 AM
                • ziplock
                  Abit BE6-II motherboard
                  by ziplock
                  Greetings,
                  I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                  I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                  04-20-2025, 02:09 PM
                  ABit IP35 Pro Motherboard Schematic
                  ABit IP35 ProABit IP35 Pro Motherboard Schematic
                  A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
                  10-31-2024, 02:06 PM
