i just clicked the cmos clear button on the mother board which is next to ps2 port and after that usb or ps2 keyboard is not detecting so i cant load windows as well simply i cant do anything with it. i tried with writing a new bios to the chip as well did not work and then heated the south bridge as well still the fault is same please help me regarding this matter.
asus croshair 4 formula motherboard falt
Re: asus croshair 4 formula motherboard falt
Do they not work in the BIOS? or is it just in windows? If you can't enter the BIOS setup be pressing delete during the POST, then I'd say it's time for a new board.I love putting bad caps and flat batteries in fire and watching them explode!!
by glovecapsHello,
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by dhenionI'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
The original board was:
ASUS X510UNR REV 3.0 A
The replacement board is:
ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...1 Photo -
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by MakNCheeseHi everyone,
I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
Symptoms:- Severe lag across the system, including BIOS navigation.
- Slow boot times and unresponsive performance in Windows.
- Battery charges very slowly (e.g., ~5% in 2–3 hours).
- No error messages or BSODs, just extreme sluggishness.
What I've Tried:- Replaced
by Ross KohlerDetails contained in these two reddit posts: https://www.reddit.com/r/Electronics...rboard_repair/ and https://www.reddit.com/r/Electronics..._super_io_chip
I've been attempting a repair of an Asus TUF H370 Gaming Motherboard. It fails to react to the power button being pressed, there's a debug light which confirms that there's standby power to the board but after any attempt to power on the components there's no sign of life. I've started my diagnosis and I know that the power-on... - Loading...
