Dell SX280's
  • simonmpoulton
    • Aug 2012
    • 12
    • united kingdom
    Dell SX280's
    Wondering if anyone can help us on these ones.
    I've got two Dell SX280's - both started off with the blinking amber light issue and had a bulging 2200uf nichicon in the same position.
    Machine 1:
    Changed just the bulging cap - seemed to work ok for a while and then started having issues with the network card - phantom data being sent etc. Changed the remainder of the 2200uf caps, same problem. Recapped all the bigger caps on the board with the exception of the processor ones (they were rubycon ones), result flashing orange light again? Checked all the solder joins on the new caps and they all seem fine.
    Machine 2:
    Changed the bulging cap and the 2 other 2200uf ones next to it. Worked fine but randomly brings up a Memory Parity Error Blue screen - any ideas on what is causing this?
  • mockingbird
    • Dec 2008
    • 5484
    Re: Dell SX280's
    Replace all Nichicon "HM" or "HN" series capacitors dated before 2005. It's unclear to me which month exactly of 2004 they started producing the new batches so it's safe to just replace anything pre-2005 and besides, they should all be pre-2005 anyway.
    The ones that you already replaced - what did you use as a replacement?
    • simonmpoulton
      • Aug 2012
      • 12
      • united kingdom
      Re: Dell SX280's
      The ones I put in were Panasonic FR 10,000 Hour 105C.
      Is there anything better I could be using? Prefer Rubycon or Panasonic.
      • selldoor
        Slow Learner
        • 7870
        Re: Dell SX280's
        Hi the cap "kit" for this has 29 caps so it suggests that all are bad/poor.
        I have no experience of this pc but have had similar symptoms with failing
        power supplies on other machines.
        Panasonic FRs should be good replacement.
        • mockingbird
          • Dec 2008
          • 5484
          Re: Dell SX280's
          Rubycon FR is not the proper replacement for Nichicon HM.
          Topcat sells a kit:
          https://www.badcaps.net/store/produc...products_id=12
          The 22uF 25v cap goes next to the CMOS battery. This cap fails frequently without showing any physical signs of failure, and will make the system exhibit all kinds of strange behavior.
          • simonmpoulton
            • Aug 2012
            • 12
            • united kingdom
            Re: Dell SX280's
            I'm in the UK so it isn't practical for me to buy from the badcaps store unfortunately.
            If the Panasonic FR are unsuitable can you please provide details of which cap series I will need to get from Farnell?
            • mockingbird
              • Dec 2008
              • 5484
              Re: Dell SX280's
              Farnell only has a very limited selection of Nichicon HM in the UK. If you order their US Stock, you have to pay a fortune for shipping.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Re: Dell SX280's
                AFAIK Topcat has even shipped to Russia with no problem - so what's keeping you from ordering from him?
                A working TV? How boring!
                • simonmpoulton
                  • Aug 2012
                  • 12
                  • united kingdom
                  Re: Dell SX280's
                  Given it is Nichicon caps that currently reside in the board i would rather avoid using them anyway. Which series of Panasonic or Rubycon caps are correct to replace the nichicons?
                  Th3 - Once you add on the shipping plus the fact that UK Customs will help themselves to Import VAT and Parcelforce UK will charge £13.50 for the priviledge of delivering the package it frankly would not be worth it. The $30 for the kit would easily double to $60.
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Re: Dell SX280's
                    Like I said, Nichicon is an excellent replacement as long as the datecode is past 2004. And you can bet that new stock Nichicon HM will be later than 04.
                    There are some Chinese sellers on that infamous auction site that have in the past shipped non-counterfeit capacitors, and the shipping is very reasonable but you will have to wait a few weeks, possibly more than a month.
                    The Rubycon equivalent to Nichicon HM/HN series is MBZ/MCZ.
                    I'm not sure about the Panasonic equivalent to HN, but the HM equivalent is Panasonic FJ. There's also a variant series "FJS" and another series "FL", but I don't know if what their specs are because I've never been able to track down their confidential datasheets.
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
                    • diamon
                      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                      by diamon
                      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                      Pictures of these boards:
                      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                      Dell...
                      02-28-2024, 12:51 PM
                    • master3112
                      by master3112
                      Yesterday, 01:55 PM
                    • OntarioTL
                      Dell 5410 greyed out BT
                      by OntarioTL
                      Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                      If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                      Dell Lattitude 5410
                      Service Tag...
                      07-25-2025, 01:28 PM
