GX270 - Removing the shield
  • n2ic
    • Apr 2012
    I am recapping a GX270. How do you remove the shield to get to C118-C124 ? Those plastic push-ins are really causing trouble.
    Thanks,
    Steve
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: GX270 - Removing the shield
    use a small awl from the underside of the board and push them out. Don't sit there and try prying them up from the top with a flat screwdriver, you'll destroy them before you ever get them out.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • n2ic
      • Apr 2012
      Thanks ! It was a struggle, but it finally popped out.
      Recapping isn't for sissies !
      Steve
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Steve
        No it ain't... Welcome to the forum, BTW.
        sigpic
        (Insert witty quote here)
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Beed there, done that.
          Actually I got 3 of them out without much damage (just a few scratches). My fingers and nails did hurt afterwards, though. I lost my nerves on the last one, so I tore that sucker into pieces.
          After recapping and putting everything back together, I found that I have screws that were the same size as those push-pins. Since I did destroy one of the push-pins, I used the screw instead. Wish I found the screws earlier. I didn't feel like taking out those other push-pins out again, so I left them there. The screw fits and works quite nicely, though.
          I think I'll post some pictures of my "fix" later this week. Had to some mods to make a standard P4 heatsink fit since I didn't have the original GX-270 one. Made a custom clip and fan holder for the heatsink, too. All using junk hardware I had laying around.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            I've broken the pins on those before. latter designs use screws
            fortunietly, I had other ones around to replace them
