MS-6156 i440BX capacitors
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    I was wondering if 8mm Rubycon MBZ 1500uf 10v would work in place of the 10mm Chhsi WG 1500uf 6.3v capacitors on the board? Or would Chemicon LXV be better for it?
    Thanks,
    urabahn5
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: MS-6156 i440BX capacitors
    yes the mbz 1500 10v will be fine and better than the LXV
    • ssl6
      MSI K7T266 Pro (Ver. 1.0)
      by ssl6
      Hey Everyone,
      Long time lurker, but I think this is my first time posting.
      Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
      I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
      11-09-2023, 01:00 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
      After all of...
      07-13-2024, 08:14 PM
    • Cama
      Solar Inverter - SMH-II - 2 missing capacitors
      by Cama
      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
      My model is : EASUN SMH-II 7 KW
      Mother Board : P/N 18947-002401250250
      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
      Thank you...
      09-12-2025, 02:50 AM
