noob! can you identify CAP for 4870x2
  • mitzibishi
    • Nov 2011
    hi. im totally new to this game. my graphics card busted and i managed to identify a bad cap. ive bought a soldering iron and im ready to go to fix it, trouble is im clueless about what cap to buy or where to buy it in UK, ive googled the numbers on the cap and nothing comes up.
    ok GFX card is HD 4870x2
    cap numbers
    834
    svp
    180
    16
    anyone point me in the right direction?
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    Re: noob! can you identify CAP for 4870x2
    Most probably it's a solid polymer capacitor and by the last two numbers I'd say it's a 180uf 16v one. Solid caps usually don't go bad. Having pics would help... What are the symptoms??
    Guns don't solve problems. I'll take 12
    • Fam787
      HELP! A1398 Dead,
      by Fam787
      I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
      Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
      12-27-2024, 05:19 PM
    • thesame
      DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
      by thesame
      Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
      The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
      02-27-2024, 04:31 AM
    • chth96
      How can I identify varistor which have been blew up?
      by chth96
      I mistakely pluged 100v japanese retro game console to 220v outlet.
      So It seems that glass fuse and varistor have been blew up.
      I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
      Is there any way to identify varistor type in my sega saturn PSU?
      Any reply would be appreciated.
      EDIT:
      It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
      11-26-2023, 08:52 AM
    • freakorio
      Need Help To Identify Component on Ymain LJ41-05120A
      by freakorio
      Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
      05-21-2024, 02:32 AM
    • baiceanu_stefan
      nm-f251 Schematic, boardview or help identify componente
      by baiceanu_stefan
      Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
      04-24-2024, 12:49 AM
